PHP Server Validations - "Headers already sent"
Thread begun 12/13/2010 10:06 am by mark284265 | Last modified 12/13/2010 12:25 pm by Jason Byrnes | 2406 views | 2 replies |
mark284265
I added a server validation to my form for a single field and now the server is throwing these error messages:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent in /WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php:3) in /WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
Any suggestions would be greatly appreciated. I've googled these messages and could not find a solution.,
mark284265
Problem solved! From a previous post:
The problem is caused by using virtual() to attach php files.
Dreamweaver will use the virtual function if you set the "Create links Relative To:" Option on the local info tab of your site definition to "Site", change that to "Document" so that Dreamweaver will use the require_once() function instead.
great, glad to hear you found the issue.
