recodset loop for email gets changed to file
Thread begun 12/13/2010 9:18 am by CUAD | Last modified 12/20/2010 6:46 pm by Dani Chankhour | 3364 views | 5 replies |
CUAD
I am trying to send a email with CSS form builder. I have it set to send through a recordset to various users and when I click finish it changes to send from file instead of the recordset. I was wonderig why this is always changing back to send from file when I want it to send from record set.
Dani Chankhour
This seems to be an issue in CSS Form Builder.
To fix this issue, Please replace your current WAUE_SBShared.js file at this location:
Configuration/ServerBehaviors/Shared/
with the attached file.
Make sure to have Dreamweaver closed and delete the cache file before restarting.
CUAD
Doesn't seem to work
Can you tell me where the path for this would be? I did replace the file but the problem still exists.
Dani Chankhour
Yes, please let me know what operating system you are using (windows or mac) and the version of Dreamweaver you are using.
You can also get the path from this pdf file:
CUAD
Windows 7 Dreamweaver CS4
Dani Chankhour
Browse to this location:
C:\Users\<Your UserName>\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration\ServerBehaviors\Shared\
