data assist not able to update record
i just simply can not update even single record with data assist update record
i have attached the file below
Please help me.
thanks very much.
Please help me.
thanks very much.
Your problem is that you are using a recordset value as the update value see line 103 of your page:
$WA_where_fieldValuesStr = "".$row_rsProducts['ProductID'] ."";
What you need to do is add a hidden form element that contains the product id and us that instead, see the revised page I have attached on the correct method.
i using data Assist wizard to do the update single record
How can I do that with wizard then? what is key column value need to set when i run the wizard?
how can i prevent this from happen when i run the update record wizard?
I have also find out that when update button press it's not redirect on submission
i have use your revised page it wont update same problem
i need help how to run the wizard?
pages created by the wizard will have a querystring set for the action of the form to pass the ID on form submit, for example:
<form action="Update_products.php?ProductID=<?php echo(rawurlencode($row_rsProducts['ProductID'])); ?>" method="post" name="UpdateForm" id="UpdateForm">
it looks like the forms action was changed after running the wizard to be blank.
why when after i runing wizard the action of the form was blank, i have attempt a couple of time still all blank, how can i set the key column value when run wizard?
i thinks i mess up the PHP code so I just delete my current page and create a new page and manually enter the querystring set for the action of the form page as you instructed
and then add a hidden form element contains the product id as the update key value, now is ok
the problem now is solve, but why when everytime i run the wizard it's left the form action blank and even no hidden form element inserted
how can i prevent this from happen again? is there any solution? please help
thanks very much for your help.
I'm not able to reproduce the problem.
can you provide some details on your system:
What is your OS?
What Version Of Dreamweaver?
What version of DataAssist?
