Submenu in Vertical Menu not properly working
Thread begun 12/12/2010 6:37 am by matt374640 | Last modified 12/12/2010 9:26 am by anonymous | 2039 views | 1 replies |
matt374640
I am using a horizontal and vertical menu on my website. I have to use z-index in both css files so the two menu are working properly. I use z-index=200 for the horizontal (main) menu and z-index=100 for the vertical submenu. But now I have the submenu of the vertical menu (Sub- submenu) not working properly. It is covered with over stuff.
See index.html and there go to Appendix A: Examples
Most likely I have to set another z-index in the css file, but I do not know in which ones. In general the combination of two menus Horizontal and vertical is not satisfactory.
anonymous
Actually, you just need to increase the left margin on this class: ul.level-1
I think you could do it from the extension dialog. Or, you could just go into the css of the vertical menu and create left margin.
Now, if you are trying to layer the flyout on top of the menu, unfortunately my understanding is that this feature cannot be done with the extension at this time. But you can increase the margin so the fly out is flush to the right edge and it will look good.
Best regards,
Brian
