DataAssist created pages as plugins - passing the values
Thread begun 12/12/2010 5:45 am by jshafor | Last modified 12/06/2013 8:18 am by Jason Byrnes | 12904 views | 13 replies |
jshafor
For starters - killer job on this extension - everyday I see it streamlining the way I work.
With that - I need a little direction.
Pages have been created with DataAssist; nothing special (insert, search, results, details, delete, update) . . .
I'm having issues loading the page correctly when it's referencing a specific item.
EXAMPLE
- The search page (....index.php? (default plugin) loads fine, no problem;
- The results page however won't display since it's looking for specified search criteria (I suspect because its a "get":
<form action="items_Results.php" method="get" name="WADASearchForm" id="WADASearchForm">)
- The dynamic plugin page I'm trying to use for the results page is ...index.php?page=itemResults; however, when I change the action on the search form from "items_Results.php" (created by DataAssist) to "...index.php?form=itemsResults" (same DataAssist page used as a plugin), it just reloads the search page.
Therefore, my question is: how do I properly and effectively use DataAssist created pages as plugins?
My goal is to run DataAssist, strip the DataAssist CSS (for the most part) and use the core code with no CSS as a plugin . . . this would be the BOMB!!
Thanks to all in advance for your input and comments.
Additional info (I know this is "old hat" for a lot of you guys - I'm still learning)
This is the string that DataAssist puts out (this if from the update page):
<form action="items_Update.php?ItemID=<?php echo(rawurlencode($row_WADAitems['ItemID'])); ?>" method="post" enctype="multipart/form-data" name="WADAUpdateForm" id="WADAUpdateForm">
The action already has ...items_Update.php?ItemID=xxx" - HOW DO I submit the form to the update page that is included on an index page as a plugin? (I don't know how to apply two ? to one string (?form= (or ?page=) and ?ItemID=) HOW DO I combine both these in one string?
Thanks!
can you send a copy of the index page so i can see how the plugins are applied.
for the second question, you would modify the code to pass both query string variables separated by the ampersand:
<form action="index.php?page=itemUpdate&ItemID=<?php echo(rawurlencode($row_WADAitems['ItemID'])); ?>" method="post" enctype="multipart/form-data" name="WADAUpdateForm" id="WADAUpdateForm">
jshafor
index.php copy
Jason - thanks for the direction on combining the two query strings . . . I'm man enough to admit that I didn't realize that could be done. I'll give that a whirl . . . thanks!
Here's a copy of the index page in question. When I submit the product search (plugin on the index.php page) it just goes back to the index.php default screen.
Just in case you want it; I also included the search page (which is a plugin on the index.php page too)
Thank you sir!
hmmm, changing the forms action to:
index.php?page=itemsResults
should do the trick. if this doesnt work, please send a link so i can investigate.
jshafor
Per the usual . . . you're definitely on the right track. I changed the form action to "index.php?page=itemsResults" and it appeared as if it did nothing; but that's not true. It's submitting the query string to the URL sting; it's just not processing it with the results page.
Here's what I mean: when I go to the search page (index.php?page=searchProducts) and just hit "Search", it loads the "index.php" (Home) page; HOWEVER, the URL string is:
index.php?S_ItemCat=&S_ItemName=&S_ItemLongDesc=&S_ItemPrice=&Search.x=35&Search.y=13&Search=Search
which is the search string welded to the end of the index.php page. Then, if I manually type the plugin extension (how you suggested prior about combining query's) with the ampersand:
index.php?page=itemsResults&S_ItemCat=&S_ItemName=&S_ItemLongDesc=&S_ItemPrice=&Search.x=35&Search.y=13&Search=Search
the results page loads as I want/need it to!
So, I said all that to ask this: how do I combine the Search query string with the plugin: www.index.php?page=itemsResults when I submit the search form?
Might I add that the solution for the issue above will allow DataAssist generated pages to integrate almost seamlessly with Framework Builder! Excellent!!
Thanks Jason - your help to myself and many others in the forum is absolutely invaluable.
on the search page, add a hidden form element named page and set the value to itemsResults:
<input name="page" type="hidden" id="page" value="itemsResults" />
jshafor
Per the usual - Jason fixed it!! Works perfectly my friend. Thanks again for your help!!
Great, glad to hear it is working.
Jenny I
Hi Jason
I am trying to do the exact same thing that jshafor is doing but I am stuck at the first hurdle. I watched the getting started video but I am still confused.
I have my default page which has links in the sidebar to all my insert/update/result/detail/search pages.
I need to insert the data assit plugins based on these urls Can you help me understan the following.
1. I go to > Framework Bulider> Insert Dynamic Plugin
2. Select Trigger Variable. (? no idea what that would be. In the get started tutorial $_GET["form"] is used, would I use that too?)
3. Create "variable value".(? In the get started tutorial "question" is used. I cannot undertand where that value came from and how it was created. Could you explain to me how this works?)
4. Finaaly creating the dynamic links (In the Getting Started tutorial the link ?form=question is used. Do Ineed to use ?form= to get my forms or are form and question generic/ variables?)
Your help is much appreciated.
with a dynamic framework, you need to have a variable and value pair. usually a query string variable is used, but it could also be a session variable.
the name of the variable and value are defined by you. In the feature tour, they are using the URL variable named "form", but you can use anything you like.
form was chosen because they are using a form page, the form querystring value is determining which form will be used. if the contact page is access with out a querystring variable:
contactus.php
it will load the contact_form.php page as a plugin
if there is a form querystring variable and it is equal to question, this will trigger the question_form.php plugin page to be loaded instead:
contactus.php?form=question
you can use any variable name / value you like. in data assist, it may make sense to use "action" as the name
and set it up so that the default is the search page:
index.php - would load the search page
set the value results to load the data assist results page:
index.php?action=results
insert to load the DataAssist insert page:
index.php?action=insert
Update for the update page
index.php?action=update
delete for the delete page
index.php?action=delete
and detail for the detail page.
index.php?action=detail
