File Upload Limitations
Thread begun 12/12/2010 4:22 am by Andrew Dodd - ADDIGITAL | Last modified 12/19/2010 4:50 am by Andrew Dodd - ADDIGITAL | 2847 views | 3 replies |
I am using UE4 on a client site (they are an entertainment agency) to allow them to post artiste videos on to the site.
Smallis files, (say typically <1Mb) upload fine, but since most of the videos are >5Mb, this seems to cause problems. Are there any inherent limitations to filesize that I'm not aware of or is there a setting I can tweak?
I can supply the page address for anybody who would like to see it.
TIA
Andrew
anonymous
Andrew,
It is not so much the internet but probably more to do with the settings in the php.ini file. Depending on your host, they may let you modify this.
If you want to find out what your current limits are, create a file... I would call it something like phptest.php.
On that file, take out everything and put this on one line: <?php phpinfo(); ?>
Then upload to your server.... open the browser and and access the file. It will show you what all the settings are.
Typically with larger files, you will need to increase certain limits... these usually include the max file upload size, the max post size, the memory limit, and the max time limit that scripts are allowed to run.
Again, depending on the host, even if they do allow you to alter these settings, they may have terms of service where you would only be allowed to increase them to a point - so be careful.
Best regards,
Brian
CraigRBeta Tester
set memory limit
another thought...
if you cannot edit php.ini you may be able to override by adding the following code to the top of your upload page
<?php ini_set('memory_limit','256M'); ?>
Thank you..
..to all who offered help and assistance.
Andrew
