DWT - Global Theme
Thread begun 12/11/2010 8:07 am by cadirks387757 | Last modified 12/13/2010 10:32 am by Jason Byrnes | 2247 views | 4 replies |
cadirks387757
DWT - Global Theme
Is there a DWT template, I see some, but really seem to behave oddly, even with Testing server enabled.
I just want to desing, Home Page images, the background image for some of the pods, and then colors.
I can swap them out for the theme it's currently using, but that is more hacking it than actually designing.
I have a DWT set for the main site, I would think could be applied in some shape or form as the base for the store as well??
Even if it's opening the home page, designing it, then product page, designing it, I'm even fine getting something like this to function.
Or can I load up, from the Theme's folder, and modify one that's in there?
Don't want to jack things up...
Thanks,
-CD
cadirks387757
Customized
But...Where is the actual shopping cart CSS...
When the item is added to the cart, that is still displaying the old theme's purple text.
I want it #444444
cart.php
The text of the item selections added to the cart, and the item description still have the old associated Purple text from the default theme.
Thanks,
-CD
neilo
Hi CD,
You need to edit the CSS in store/webassist/themes/NM3/css/configurable.css for class 'productCart' (line 299) to change the color of the cart text.
Change:
.productCart {
color: #5B3977;
.productCart {
color: #444444;
Changing colors in the CSS is generally safe, but be aware that changing other properties could lead to unexpected results, as adjusting a class or ID property to get the desired results on one page may reflect badly on another page if that page has elements that use the same IDs or classes. Back up your pages and CSS files before making any major changes.
The reason that your change didn't 'take' is that the styles 'cascade' (Cascading Style Sheets) so your edits to lines that appear earlier on in the stylesheet will be negated by any rules that appear later on in that stylesheet.
Similarly, if more than one stylesheet is referenced in the header of your page, styles for IDs and classes with the same names in the later referenced stylesheet will supersede rules written in the earlier one(s).
If I were setting out to make significant changes to the CSS in pages that I did not design and create myself, I would be inclined to leave all the original stylesheets as they are, and create a new stylesheet (i.e. 'mystyles.css') and include that in the page headers after any existing css imports or includes, and add my own specific class and ID style rules to that stylesheet. That way, if things go pear-shaped, I know where to look for any errors and, if necessary, I can just revert to the original design rules by removing the references to my own stylesheet from the page headers.
cadirks387757
That did the trick. Thank you very much...
Can you edit product page designs?
So it's populating options, sub-options, description based on the admin panel.
Can you open that master product template, and move the content boxes around? (leaving there ID's in tact and such so as not to jack anything up)....
I have a lot on a couple of them, even modifying specific product pages would be awesome.
products_detail.php?ProductID=375
There are a few drop downs on this one. :)
If I could Title a few, move some below the image, get a little separation on there, could look a lot better...
Thanks Again!
-CD
most of the product details page is created dynamicly.
the page that creates it is the plugins/catalog/details.php page.
you would need to be very proficient in PHP to change the design of this page in the way you are describing.
