Why are my page titles not appearing ?
Thread begun 12/10/2010 8:51 am by Dave Buchholz | Last modified 12/10/2010 9:13 am by Jason Byrnes | 2303 views | 2 replies |
Dave BuchholzBeta Tester
I am building a small site for a local mechanic which I am using as a test bed for the CMS I am developing using Framework Builder and all the content for the various "pages" is pulled in via Framework Builder.
This is the code I am using
Load Site Application File
require_once('_inc/application.php');
Set $includedOnPage Variable to ensure plugins cannot be
viewed outside the context of this page
if(!(isset($includedOnPage)) || (!(empty($includedOnPage)))) $includedOnPage true;
require_once( "webassist/framework/library.php" );
require_once(
"webassist/framework/framework.php" );
require_once('Connections/connDB.php'); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
  if (
PHP_VERSION 6) {
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
$urlParam_rsMenuLevel1 "-1";
if (isset(
$pathInfo[0])) {
$urlParam_rsMenuLevel1 = (get_magic_quotes_gpc()) ? $pathInfo[0] : addslashes($pathInfo[0]);
mysql_select_db($database_connDB$connDB);
$query_rsMenuLevel1 sprintf("SELECT slug FROM tbl_pages WHERE slug = %s"GetSQLValueString($urlParam_rsMenuLevel1"text"));
$rsMenuLevel1 mysql_query($query_rsMenuLevel1$connDB) or die(mysql_error());
$row_rsMenuLevel1 mysql_fetch_assoc($rsMenuLevel1);
$totalRows_rsMenuLevel1 mysql_num_rows($rsMenuLevel1);
$urlParam_rsMenuLevel2 "-1";
if (isset(
$pathInfo[1])) {
$urlParam_rsMenuLevel2 = (get_magic_quotes_gpc()) ? $pathInfo[1] : addslashes($pathInfo[1]);
$query_rsMenuLevel2 sprintf("SELECT slug FROM tbl_pages WHERE slug = %s"GetSQLValueString($urlParam_rsMenuLevel2"text"));
$rsMenuLevel2 mysql_query($query_rsMenuLevel2$connDB) or die(mysql_error());
$row_rsMenuLevel2 mysql_fetch_assoc($rsMenuLevel2);
$totalRows_rsMenuLevel2 mysql_num_rows($rsMenuLevel2);
if((!(
$totalRows_rsMenuLevel1 == 0)) && ($totalRows_rsMenuLevel2 == 0)){
$WA_level1_1288197075810 = new WA_Include("_plugins/category-pages/category-page.php");
    require(
$WA_level1_1288197075810->BaseName);
$WA_level1_1288197075810->Initialize(true);
if(!(
$WA_level2_1288197258702 = new WA_Include("_plugins/subcategory-pages/subcategory-page.php");
    require(
$WA_level2_1288197258702->BaseName);
$WA_level2_1288197258702->Initialize(true);
# Fire the WebAssist Framework Builder Dynamic Plug-in only if all of the above recordsets are empty
if(($totalRows_rsMenuLevel1 == 0) && ($totalRows_rsMenuLevel2 == 0)){
if(true){
// WebAssist Framework Builder Dynamic Plug-in: $WA_page_1288220530067
switch(isset($pathInfo[0])?$pathInfo[0]:""){
        case
$WA_page_1288220530067 = new WA_Include("_plugins/home-page/home.php");
            break;
        case
"index":
            break;
        case
"about":
$WA_page_1288220530067 = new WA_Include("_plugins/about-us-pages/about-us.php");
            break;
        case
"contact":
$WA_page_1288220530067 = new WA_Include("_plugins/contact-pages/contact-us.php");
            break;
        case
"legal":
$WA_page_1288220530067 = new WA_Include("_plugins/legal-pages/legal-page.php");
            break;
        case
"forbidden":
$WA_page_1288220530067 = new WA_Include("_plugins/error-pages/page-forbidden.php");
            break;
        default:
$WA_page_1288220530067 = new WA_Include("_plugins/error-pages/page-not-found.php");
            break;
    if(isset(
$WA_page_1288220530067)){
        require(
$WA_page_1288220530067->BaseName);
$WA_page_1288220530067->Initialize(true);
// End: WebAssist Framework Builder Dynamic Plug-in: $WA_page_1288220530067
# End fire if all recordsets are empty
and this is the code in the title tag
<title><?php echo((isset($WA_level1_1288197075810))?$WA_level1_1288197075810->Title:""?><?php echo((isset($WA_level2_1288197258702))?$WA_level2_1288197258702->Title:""?><?php echo((isset($WA_page_1288220530067))?$WA_page_1288220530067->Title:""?></title>
The title tag content appears just fine from the dynamic plugin but not the two static ones e.g. contact/ the title tag content appears but mot/ it doesn't
What am I doing wrong ?
Ignore this, the title tags in question had become corrupted and now I have corrected that the issue has resolved itself.
ok, glad to hear it is working
