Disappearing Insert on Registration page
Thread begun 12/09/2010 3:35 pm by bjgarner241692 | Last modified 12/10/2010 10:59 am by bjgarner241692 | 3803 views | 6 replies |
bjgarner241692
I have run this wizard 4 times.
When it doesn't simply stop responding it creates pages without all of the necessary code. The Registration page has no insert code and the Profile page has no Update code.
Should have known better. Earlier this week I had to reinstall eCart 5 and since then it's been nothing but javascript errors. Data Assist had to be reinstalled as well.
Do I just reinstall Security Assist?
Extremely Frustrating! I wish your extensions would play together better!
Following is the entire code of the Registration page that is created.
// *** Redirect if username exists
$MM_flag="MM_insert";
if (isset(
$_POST[$MM_flag])) {
$MM_dupKeyRedirect="students_duplicate.php";
$loginUsername = $_POST['email'];
$LoginRS__query = "SELECT email FROM students WHERE email='" . $loginUsername . "'";
mysql_select_db($database_conn, $conn);
$LoginRS=mysql_query($LoginRS__query, $conn) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
//if there is a row in the database, the username was found - can not add the requested username
if($loginFoundUser){
$MM_qsChar = "?";
//append the username to the redirect page
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername;
header ("Location: $MM_dupKeyRedirect");
    exit;
require_once('Connections/conn.php'); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  if (
PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return
$theValue;
$editFormAction
= $_SERVER['PHP_SELF'];
if (isset(
$_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "WAATKRegistrationForm")) {
$insertSQL = sprintf("INSERT INTO students (lastname, firstname, email, pwd) VALUES (%s, %s, %s, %s)",
GetSQLValueString($_POST['lastname'], "text"), GetSQLValueString($_POST['firstname'], "text"), GetSQLValueString($_POST['email'], "text"), GetSQLValueString($_POST['pwd'], "text"));
$Result1 = mysql_query($insertSQL, $conn) or die(mysql_error());
$insertGoTo = "students_LogIn.php";
  if (isset(
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>Registration</title>
<link href="WA_SecurityAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="WA_SecurityAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="RegistrationContainer" class="WAATK">
  <form  action="<?php echo $editFormAction; ?>" method="post" name="WAATKRegistrationForm" id="WAATKRegistrationForm">
    <h1>Registration</h1>
    <table class="WAATKDataTable" cellpadding="0" cellspacing="0" border="0">
      <tr>
        <th>lastname:</th>
        <td><input type="text" class="WAATKTextField" name="lastname" id="lastname" value="" size="32" /></td>
      </tr>
      <tr>
        <th>firstname:</th>
        <td><input type="text" class="WAATKTextField" name="firstname" id="firstname" value="" size="32" /></td>
      </tr>
      <tr>
        <th>email:</th>
        <td><input type="text" class="WAATKTextField" name="email" id="email" value="" size="32" /></td>
      </tr>
      <tr>
        <th>pwd:</th>
        <td><input type="text" class="WAATKTextField" name="pwd" id="pwd" value="" size="32" /></td>
      </tr>
    </table>
    <div class="WAATKButtonRow">
      <input type="image" hspace="0" vspace="0" border="0" name="Register" id="Register" value="Register" alt="Register"  src="WA_SecurityAssist/images/Pacifica/Refined_register.gif"  />
      <input type="hidden" name="MM_insert" value="WAATKRegistrationForm">
    </div>
  </form>
</div>
</body>
</html>
Security Assist version is 1.1.8
bjgarner241692
Attempt 6 with v 1.1.9 produces the exact same result.
if (isset(
$MM_qsChar = "?";
    exit;
function
  if (
PHP_VERSION < 6) {
  switch (
$theType) {
    case
"text":
      break;
    case
"long":
    case
"int":
      break;
    case
"double":
      break;
    case
"date":
      break;
    case
"defined":
      break;
  return
$theValue;
$editFormAction
if (isset(
  if (isset(
<html>
<head>
</head>
<body>
      <tr>
        <th>lastname:</th>
      </tr>
      <tr>
        <th>firstname:</th>
      </tr>
      <tr>
        <th>email:</th>
      </tr>
      <tr>
        <th>pwd:</th>
      </tr>
    </table>
    </div>
  </form>
</div>
</body>
</html>
bjgarner241692
By moving this:
<?php require_once('Connections/conn.php'); ?>
function
  if (
PHP_VERSION < 6) {
  switch (
$theType) {
    case
"text":
      break;
    case
"long":
    case
"int":
      break;
    case
"double":
      break;
    case
"date":
      break;
    case
"defined":
      break;
  return
$theValue;
to the top I can at least get the record to insert, but DW still says that the Insert Behaviour is missing. I've opened older pages that I have created and it's the same thing.
Check Name has an Exclamation mark next to it and if you double click it says the insert behaviour has been deleted.
bjgarner241692
Next:
User can now Register - goes to Login page
Login fails and user is redirected to failture page.
Removed Page Access code from user profile page, logged in again, works fine so username and password are fine.
Inserted page access code again on user profile page, refreshed page, login fails.
login page
if (!isset($_SESSION)) {
session_start();
require_once('Connections/conn.php');?>
require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?><?php
if ((((isset($_POST["autologinoption"]))?$_POST["autologinoption"]:"") != ""))     {
setcookie("AutoLoginPWD", "".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"")  ."", time()+(60*60*24*30), "/", "", 0);
?><?php
setcookie("AutoLoginUN", "".((isset($_POST["username"]))?$_POST["username"]:"")  ."", time()+(60*60*24*30), "/", "", 0);
?><?php
if ((((isset($_POST["remembermeoption"]))?$_POST["remembermeoption"]:"") != ""))     {
setcookie("RememberMePWD", "".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"")  ."", time()+(60*60*24*30), "/", "", 0);
?><?php
setcookie("RememberMeUN", "".((isset($_POST["username"]))?$_POST["username"]:"")  ."", time()+(60*60*24*30), "/", "", 0);
?><?php
if (isset($_POST["LogIn_x"]) && !isset($_POST["remembermeoption"]))     {
setcookie("RememberMePWD", "", time()+(60*60*24*30), "/", "", 0);
?><?php
setcookie("RememberMeUN", "", time()+(60*60*24*30), "/", "", 0);
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => $conn,
"database" => $database_conn,
"tableName" => "students",
"columns" => explode($WA_Auth_Separator,"email".$WA_Auth_Separator."pwd"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"")  ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"")  .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"stID"),
"sessionNames" => explode($WA_Auth_Separator,"stID"),
"successRedirect" => "students_Profile.php",
"failRedirect" => "students_EmailPW.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
if((((isset($_SESSION["stID"]) && $_SESSION["stID"] != "")?"LoggedIn":"") == "")&&(((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") != "")&&(((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"") != "")){
"columnValues" => explode($WA_Auth_Separator,"".((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"")  ."".$WA_Auth_Separator."".((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"")  .""),
"failRedirect" => "",
<html>
<head>
<title>Log In</title>
</head>
<body>
<div id="LogInContainer" class="WAATK">
  <form  action="<?php echo ($_SERVER["PHP_SELF"].(isset($_SERVER["QUERY_STRING"])?"?".htmlentities($_SERVER["QUERY_STRING"]):""));?>" method="post" name="WAATKLogInForm" id="WAATKLogInForm">
    <h1>Log In</h1>
      <tr>
        <th>User name</th>
        <td><input type="text" class="WAATKTextField" name="username" value="<?php echo((isset($_COOKIE["RememberMeUN"]) && isset($_COOKIE["RememberMePWD"]))?$_COOKIE["RememberMeUN"]:"") ?>" /></td>
      </tr>
      <tr>
        <th>Password</th>
        <td><input type="password" class="WAATKTextField" name="userpassword" value="<?php echo((isset($_COOKIE["RememberMePWD"]))?$_COOKIE["RememberMePWD"]:"") ?>" /></td>
      </tr>
      <tr>
        <th class="WAATKDataTableHeader"><input type="checkbox" name="remembermeoption" <?php echo((isset($_COOKIE["RememberMeUN"]))?"checked":"") ?> value="1" /></th>
        <td class="WAATKDataTableCell">Remember me</td>
      </tr>
      <tr>
        <th class="WAATKDataTableHeader"><input type="checkbox" name="autologinoption"  value="1" /></th>
        <td class="WAATKDataTableCell">Auto log in</td>
      </tr>
    </table>
      <input type="image" hspace="0" vspace="0" border="0" name="LogIn" id="LogIn" value="Log In" alt="Log In"  src="WA_SecurityAssist/images/Pacifica/Refined_login.gif"  />
    </div>
  </form>
</div>
</body>
</html>
bjgarner241692
Profile Page:
session_start();
if (!
WA_Auth_RulePasses("Logged in to students")){
WA_Auth_RestrictAccess("students_EmailPW.php");
if (!
function
  if (
PHP_VERSION < 6) {
  switch (
$theType) {
    case
"text":
      break;
    case
"long":
    case
"int":
      break;
    case
"double":
      break;
    case
"date":
      break;
    case
"defined":
      break;
  return
$theValue;
$editFormAction
if (isset(
if ((isset($_POST["MM_update"])) && ($_POST["MM_update"] == "WAATKUpdateForm")) {
$updateSQL = sprintf("UPDATE students SET lastname=%s, firstname=%s, pwd=%s WHERE stID=%s",
GetSQLValueString($_POST['lastname'], "text"), GetSQLValueString($_POST['firstname'], "text"), GetSQLValueString($_POST['pwd'], "text"), GetSQLValueString($_POST['stID'], "text"));
$Result1 = mysql_query($updateSQL, $conn) or die(mysql_error());
$updateGoTo = "students_Profile.php";
  if (isset(
$updateGoTo .= (strpos($updateGoTo, '?')) ? "&" : "?";
$updateGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $updateGoTo));
$ParamstID_WAATKstudents
= "-1";
if (isset(
$_SESSION['stID'])) {
$ParamstID_WAATKstudents = (get_magic_quotes_gpc()) ? $_SESSION['stID'] : addslashes($_SESSION['stID']);
$query_WAATKstudents = sprintf("SELECT * FROM students WHERE stID = %s", $ParamstID_WAATKstudents);
$WAATKstudents = mysql_query($query_WAATKstudents, $conn) or die(mysql_error());
$row_WAATKstudents = mysql_fetch_assoc($WAATKstudents);
$totalRows_WAATKstudents = mysql_num_rows($WAATKstudents);
<html>
<head>
<title>Profile</title>
</head>
<body>
<div id="UpdateContainer" class="WAATK">
  <?php if ($totalRows_WAATKstudents > 0) { // Show if recordset not empty ?>
    <form  action="<?php echo $editFormAction; ?>" method="post" name="WAATKUpdateForm" id="WAATKUpdateForm">
      <h1>Profile</h1>
        <tr>
          <th>lastname:</th>
          <td><input type="text" class="WAATKTextField" name="lastname" id="lastname" value="<?php echo(str_replace('"', '&quot;', $row_WAATKstudents['lastname'])); ?>" size="32" /></td>
        </tr>
        <tr>
          <th>firstname:</th>
          <td><input type="text" class="WAATKTextField" name="firstname" id="firstname" value="<?php echo(str_replace('"', '&quot;', $row_WAATKstudents['firstname'])); ?>" size="32" /></td>
        </tr>
        <tr>
          <th>email:</th>
          <td><?php echo(str_replace('"', '&quot;', $row_WAATKstudents['email'])); ?></td>
        </tr>
        <tr>
          <th>pwd:</th>
          <td><input type="text" class="WAATKTextField" name="pwd" id="pwd" value="<?php echo(str_replace('"', '&quot;', $row_WAATKstudents['pwd'])); ?>" size="32" /></td>
        </tr>
      </table>
        <input type="image" hspace="0" vspace="0" border="0" name="Update" id="Update" value="Update" alt="Update"  src="WA_SecurityAssist/images/Pacifica/Refined_update.gif"  />
        <input name="stID" type="hidden" id="WAATKUpdateRecordID" value="<?php echo(rawurlencode($row_WAATKstudents['stID'])); ?>">
        <input type="hidden" name="MM_update" value="WAATKUpdateForm">
      </div>
    </form>
  <?php } // Show if recordset not empty ?>
  <?php if ($totalRows_WAATKstudents == 0) { // Show if recordset empty ?>
    <div>No record found.</div>
  <?php } // Show if recordset empty ?>
</div>
</body>
</html>
mysql_free_result
($WAATKstudents);
All code is straight fromt he wizard with the exception that I removed the extra conn string from the profile page. That's pretty common with these behaviours. Strings are inserted pretty much every time you edit a behaviour.
the only issue i see on he original registration page is the location of the connection require once line, it should be moved to line 1 so the connection is defined before the check new user name function.
For the login issue, are you testing remotely or locally?
If testing remotely, make sure that the WA_SecurityAssist folder is being uploaded to the server. If you are still having a problem, add the following code after the body tag on the profile page so i can see the sessions being set:
<?php var_dump($_SESSION); ?>
and send a copy of the WA_SecurityAssist/HelperGroupRules.php page.
I've tried testing on Windows 7, Vista and Mac OS using Security Assist 1.1.8 and 1.1.9 in DWCS4 and DWCS5 and i cannot recreate the issue you are reporting. I tested both before and after installing EC5 and DA2.
bjgarner241692
Login works - apparently the WA_Security folder did not upload earlier.
Still though, in DW, you cannot bring up the Insert Behaviour on this page and the Check Names behaviour shows an error.
As for the order that the code is generated in, why does it do it wrong?
I should be able to run one of your wizards and get a properly functioning page that I can edit using your tools.
This is a new problem on my system, so I am sure it is the usual problem with your WA extensions. Depending on the order in which you install them they work or they don't because too often one extension overwrites files needed by another extension.
The frustrating thing is that the fix is ridiculous - remove all the extensiond replace them until yet another set of WA script errors starts popping up.
