Installation Issues - 2.10
Thread begun 12/09/2010 10:58 am by debbie295402 | Last modified 12/10/2010 6:48 am by Jason Byrnes | 2338 views | 3 replies |
debbie295402
I started with CMS 2.01 and got everything set up including the database. When I got to the login page, it went nowhere, just a clink that the button had been pushed. I checked the db and found the username and password was correct, but no luck on any browser.
I removed everything from the server, except the db, and then installed the latest version, 2.10. When I get to the set up screen, I get the following errors:
Warning: session_start() [function.session-start]: open(/var/php_sessions/sess_2ad768ab321ed1778de311e75eb7be7f, O_RDWR) failed: No such file or directory (2) in /hermes/bosweb/web174/b1740/ipw.zontadis/public_html/CMS/install_cms/global.php on line 6
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /hermes/bosweb/web174/b1740/ipw.zontadis/public_html/CMS/install_cms/global.php:6) in /hermes/bosweb/web174/b1740/ipw.zontadis/public_html/CMS/install_cms/global.php on line 6
Warning: Cannot modify header information - headers already sent by (output started at /hermes/bosweb/web174/b1740/ipw.zontadis/public_html/CMS/install_cms/global.php:6) in /hermes/bosweb/web174/b1740/ipw.zontadis/public_html/CMS/install_cms/wizard.php on line 43
Warning: Unknown: open(/var/php_sessions/sess_2ad768ab321ed1778de311e75eb7be7f, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/php_sessions) in Unknown on line 0
Not sure where to go from here, but would appreciate a quick solution as the client is waiting. I'm on CS5, Windows 7. I've got on error logging and issue can be seen at CMS
Thanks in advance.
the error means that the servers session management is not configured correctly.
you will need to contact the host to have them fix the issues with the session management settings.
debbie295402
What exactly is the issue with the session management so I can hopefully converse semi-intelligently with the hosting service (which is ipower.com)?
Is there something specific I should ask them to resolve?
Thanks for the quick response!
they should be able to look at the error and have an idea of the problem.
Usually, it is an issue with the session.save_path in the php.ini file, but i cannot say for certain.
