Form submits even with validation applied
Thread begun 12/08/2010 4:52 pm by elewis93815 | Last modified 12/15/2010 7:19 am by Jason Byrnes | 5674 views | 5 replies |
elewis93815
Hello,
I have recently inserted captcha security on a form that we have created, applied server validation and created an error message if an error occurs. We attempt to generate an error but the form submits.
Not sure if this is a problem however, we are using gdform.php script for the form:
$request_method = $_SERVER["REQUEST_METHOD"];
if($request_method == "GET"){
$query_vars = $_GET;
} elseif ($request_method == "POST"){
$query_vars = $_POST;
reset($query_vars);
$t = date("U");
$file = $_SERVER['DOCUMENT_ROOT'] . "/../data/gdform_" . $t;
$fp = fopen($file,"w");
while (list ($key, $val) = each ($query_vars)) {
fputs($fp,"<GDFORM_VARIABLE NAME=$key START>\n");
fputs($fp,"$val\n");
fputs($fp,"<GDFORM_VARIABLE NAME=$key END>\n");
if ($key == "redirect") { $landing_page = $val;}
fclose($fp);
if ($landing_page != ""){
header("Location: http://".$_SERVER["HTTP_HOST"]."/$landing_page");
} else {
header("Location: http://".$_SERVER["HTTP_HOST"]."/");
Not sure why this isn't working??? Any help is greatly appreciated.
Thanks,
Jackie
I've also attached the files, if that helps.
this is the most common problem with forms and validation.
you have the action of the form to post to another page:
<form id="form1" name="form1" method="post" action="gdform.php">
when the form posts, it posts directly to the action page.
all form processing (Including server validation) must occur on the forms action page.
elewis93815
Thanks, I swapped the <form id="form1" name="form1" method="post" action="gdform.php"> with <form id="form1" name="form1" method="post" action="contact.php"> and it does error out (which I wanted t to do), however when it errors out it deletes all of the form entry data, is there a way to have it leave the form entry data in place?
Erick
bind the form elements initial value to the corresponding binding in the Validated Entries collection.
p.woodall208922
Still getting problems
Jason it would have been very useful if, in the tutorial, the guide and the UTube video, the fact that validation must be actioned from the page the form is situated upon, had been mentioned. Perhaps this amendment could be made as a matter of urgency to prevent your Clients wasting valuable time.
I have now spent over a week following these guides religously only to note I was clearly wasting my time. Critical facts such as this should NOT be overlooked by WebAssist making the erroneous assumption that the Client will know.
That said for many people, myself included, having the action sent to the page that the form is on is of little use. I have a form which is not actioned on the "form" page at all, but rather via an external form processor and my previous validation method was done from an "onsubmit" action on the page the form lay on.
See contact.php
The form processor, is named formail.php, and is important, as it does many other functions not related to field validation at all. (e.g. redirects to a thank you page upon sucessful submission, checks that the form submitted is a valid submission)
If one is to use Form Toolkit we therefore require a facility to relate it to an onsubmit action - (i.e. Client side validation), on the submitted page, so that both our own form processor AND your field validation can work independantly of each other.
Regards
Peter Woodall
i you feel that something is missing from the documentation or have any documentation suggestions or feedback, please submit these directly to the documentation team through our feedback form:
feedback.php?type=docs
The main feature of Form Toolkit is captcha. captcha validation cannot be processed client side, it must be processed server side.
the main drawback to client side validation is that it relies on Javascript. the user can get around client side validation by disabling javascript in the browser.
Server side validation cannot be turned off however.
in form toolkit, there is a form data binding tool added to the bindings panel.
this can be used to import form dynamic bindings from the form page to the forms action page enabling you to add the server validation to the action page if it is a different page from the form itself.
you could open you form processing page, then go to the bindings panel, click the plus button and select Form Data. in the form data window, click the folder icon and select the form page.
Form toolkit does not include client side validation, client side validation is included with CSS Form Builder.
