Search working on some pcs and not on others
Thread begun 12/08/2010 12:09 pm by dallySP | Last modified 12/09/2010 6:59 am by Jason Byrnes | 1978 views | 3 replies |
dallySP
OK here's a wierd one. Can you check out this address:
http://www.rtfactflowers.co.uk
I'd had some problems with the search box previously which I think are now fixed. It works fine for me, but my customer tells me that when they search for say 'roses' it returns all the items in the database. I've asked a couple of other people to test off-site, one said it worked fine and the other said it didn't. I know the search criteria is stored in a session, could it be that this is lingering from a previous search on customers system, and how can I fix it?
Thanks for your help. Search results page is attached.
change line 20:
if (isset($_POST["Search_x"])) {
if (isset($_POST["criteria"])) {
most likely the ones it is not working for are using IE.
In IE, there is a bug where small forms sometimes do not pass the submit button with the form post.
dallySP
All sorted - what a great service you guys give - thank you so much.
Great, glad to hear it is working.
