Can someone help me finish the WHERE statement? -based on itemID from cart contents
Thread begun 12/08/2010 9:29 am by john42771 | Last modified 12/09/2010 10:56 am by Jason Byrnes | 2404 views | 3 replies |
john42771
I want to display only those records whose cart's content "itemID" is in the cart.
BUT the cart contents do NOT contain ALL the information that the corresponding db table has in it (which I want to display here).
The final objective is show the item's additional information on the confirm.php page below the shopping cart display.
SELECT *
FROM PD_Courses
**eCart Contents ItemID*****help needed here*****eCart Contents ItemID**
WHERE PD_Courses.CoursesID = <?php echo $eCart1->DisplayInfo("ID"); ?>
ORDER BY DisplayOrder ASC
Thank you in advance your time and know-how,
John
your query is correct already:
SELECT *
FROM PD_Courses
you just need to place it in a cart loop along with the code to display it:
<?php while (!$eCart1->EOF()) { ?>
<recordset here>
<code to display record information here>
$eCart1->MoveNext();
$eCart1->MoveFirst();
john42771
Thanks very much Jason.
you're welcome.
