The <p> tag issue - is it solved?
Thread begun 12/07/2010 12:25 pm by info360637 | Last modified 12/08/2010 12:52 pm by Jason Byrnes | 2342 views | 4 replies |
info360637
Hi - I was wondering if there is a fix to the automatic adding of a <p></p> tag to text by default? I'm using Power CMS 2,01 and I've tried editing the various .js files to be 'br' on enter, not p - but makes no difference?
Is going to be a problem if it can't be fixed.....
thanks
Jim
Do you have a sample page where you have made that change? I think it won't add the p if you set the .js to use br on enter... does it add the br?
there are 5 files that need to be edited:
HTMLEditor/custom/contents_insert_ContentValue1.js
HTMLEditor/custom/contents_insert_ContentValue1.php
HTMLEditor/custom/contents_update_ContentValue1.js
HTMLEditor/custom/contents_update_ContentValue1.php
HTMLEditor/fckconfig.js
in all 5 of those files, find the line:
FCKConfig.EnterMode = 'p' ;
and change it to:
FCKConfig.EnterMode = 'br' ;
info360637
That's nailed it :-)
Thanks Jason
best regards,
Jim
glad to hear it is working.
