How do I insert form into existing html page?
Thread begun 12/07/2010 10:53 am by bernwa414284 | Last modified 12/08/2010 12:46 pm by Jason Byrnes | 8483 views | 14 replies |
bernwa414284
How do I insert the form into existing html page? I already have a contact page designed and simply want to insert the form into a content div? The instructions are very scarce with this product I must say.
Thank you
copy all of the code from the contact form page that is above the doctype tag, and paste it to your existing page above the doctype tag.
copy the form from the contact page from the opening form tag to the closing form tag. pate this to your existing contact page.
bernwa414284
Thanks Jason. I'm making a little progress. But form some reason the security code does not show when I view the page, so I can not submit the form. here is the page if you wouldn't mind taking a look.
I appreciate your help!
BC
BVCContact.php
seams to show the security code when i test it.
when i submit the form, i get an error that the WA_Universal_Email folder has not been uploaded to the server though. make sure to upload the WA_Universal_Email folder.
bernwa414284
Thanks again for your help.
That folder was uploaded.
This is the message I'm getting:
Warning: main(/home/content/b/v/c/bvcwebdesign/html/WA_Universal_Email/BVCContact.php) [function.main]: failed to open stream: No such file or directory in /home/content/b/v/c/bvcwebdesign/html/WA_Universal_Email/WAUE_contact_1.php on line 43
Fatal error: main() [function.require]: Failed opening required '/home/content/b/v/c/bvcwebdesign/html/WA_Universal_Email/BVCContact.php' (include_path='.:/usr/local/lib/php') in /home/content/b/v/c/bvcwebdesign/html/WA_Universal_Email/WAUE_contact_1.php on line 43
The form again is at:
BVCContact.php
Thanks again and I look forward to your help!
BC
send a copy of the bvccontact.php page please.
bernwa414284
I can't seem to attach it. How should I send it?
add the php file to a zip archive and attach the zip file please.
bernwa414284
See attached. Thanks!
looks like the error is coming out of the WA_Universal_Email/WAUE_contact_1.php file, can you send that one also.
