File Manipulation Download
Thread begun 12/07/2010 9:35 am by agmichaca | Last modified 12/07/2010 10:13 am by agmichaca | 1838 views | 2 replies |
agmichaca
I am using File Manipulation download, and I follow step by step the turorial.
I insert the behavior and doesn't work.
I am using dynamic filenames, and in order to work I have to add by hand the dot and the file extension name (.pdf) to the File name field.
Is this the correct procedure? what happend if I used different extension name?
Besides the counter doesn´t work.
Please see the attached file.
Thanks.
you shouldn't need to add the .ext to the end if that database is toring the ful file name.
in the download you are using the expedients column what is the value stored in that column?
it sounds like the value stored in that column is the file name excluding the extension.
the download counter is expecting to get the id from the id_exp querystring variable which is not present when the download form posts.
you need to modify the form action to pass the querystring variable:
<form action="pageName.php?id_exp=<?php echo(isset($_GET['id_exp'])?$_GET['id_exp']:""); ?>" method="post" id="formDescarga">
agmichaca
Thank you Jason,
The expedients column store the file name, but I tried with and without extension name and doesn´t work. [After changed the Form it works]
What type of field for the counter in the DB I need?
