Failed validation produces unexpected results
Thread begun 12/07/2010 5:24 am by Airfox | Last modified 12/09/2010 11:09 am by Jason Byrnes | 2321 views | 3 replies |
Airfox
I’m having a similar problem to showthread.php?t=17413
I have downloaded the two patch files and deleted .dat file, but this had no effect, I’m still getting the problem.
I’m trying to apply form validation, to a user registration form (created with security assistant, as part of an eCart project).
For each field I have set value=’<?php echo((isset($_POST["field-1"]))?$_POST["form_field"]:"") ?>’ this is to save the user re-entering all the data when a validation fails
It’s just not behaving as I expected. I just get empty fields when the validation fails.
To explore further, I have created a simple test page:
<body>
<form action="test.php" name="test" id="test" method="post" target="_self">
<input name="field-1" type="text" value="<?php echo((isset($_POST["field-1"]))?$_POST["field-1"]:"") ?>" size="30" />
<input name="field-2" type="text" value="<?php echo((isset($_POST["field-2"]))?$_POST["field-2"]:"") ?>" size="30" />
<input type="submit" />
</form>
</body>
This works perfectly until I add validation.
Field-1 has no validation, field-2 has ‘required/not-blank’ validation.
The results are:
Null null --> null null (This I expected)
Foo null --> null null (This is not what I hoped for - field-1 should display foo)
Null foo --> null foo (This I expected)
Foo foo --> foo foo (This I expected)
I will attach the test page and the two wa config files, could you take a quick look please?
:o)
do not use the form values for failed validation.
you need to bind the WA Validated Entries collection instead.
the validated entries collection is created to capture the form values when validation fails.
Airfox
Bingo !!
Thanks for that, works perfectly now!
This is such a cute lil extension... click, click, click and its all done.
Saves so much time.
:o)
glad to hear it is working.
