Date Picker not working if inserted in a repeat region
Thread begun 12/07/2010 4:18 am by Suggs | Last modified 4/26/2013 12:07 pm by Jason Byrnes | 4087 views | 6 replies |
Suggs
Hi Folks,
Any help will be appreciated here.
I have a date picker inserted in a repeat region and it will only work on the first item, instead of being repeated through all items.
Can you advise as to what I need to do to have it work with all items in the repeated region.
Cheers
Suggs
Can anyone help me with this please?
Any help will be greatly appreciated
at this time the date picker is not compatible with repeat regions. I have loged a bug to have the problem looked into for a future update.
anonymous
Has this been resolved?
Has this been resolved? Please advise. I still can't get the datepicker to work in a repeat region (in this case, a repeat cart region). Thanks in advance for your response.
No, the date picker is not compatible for use in a repeat region.
anonymous
Ideas on a work-around for datepicker incompatibility?
Thanks for the response. Do you have any ideas for a work-around (e.g. another datepicker plugin that is compatible or other suggestion)? Any suggestion is greatly appreciated.
I am not aware of a date picker that is compatible with repeat regions. There is really not a work around to make the Data Bridge date picker work in a repeat region.
