moving PowerGallery
Thread begun 12/07/2010 3:47 am by PeterL | Last modified 12/08/2010 6:43 am by Jason Byrnes | 2400 views | 3 replies |
PeterL
moving PowerGallery
Hello,
i was searching this forum but could not find the answer;
I set up PowerGallery on a subdomain and i want to move it to the main domain now.
Unlike PowerCMS by sample i can not find a file where i can change the path.
path is now: /home/httpd/vhosts/mysite.com/subdomains/nieuw/httpdocs
and i have to change this to: /home/httpd/vhosts/mysite.com/httpdocs
Can anyone help me with this issue?
Thanks,
PeterL
what version of power gallery is this?
In reality, power gallery is not intended to be moved. It is intended to be run in place where it is installed, you may be best reinstalling the gallery to the new location.
PeterL
The version is 1.00
Than unfortunately i have to re-install everything.
But what about the PowerGallery database integration; is that not ment for moving??
Can i use this in future to make life easyer?
PeterL
with version 1, you should be able to change the address in the wa_settings table by editing the pg_root and pg_rooturl
