API info won't accept when Finish is pressed
Thread begun 12/06/2010 7:02 pm by martin.g.robbins419510 | Last modified 8/09/2013 3:58 pm by Ray Borduin | 10549 views | 23 replies |
I put in my API Username, API Password, and API Signature but when I press Finish nothing happens. What am I doing wrong? Here's my DreamWeaver CS4 information: Version 10 Build 4117. Any suggestions will be greatly appreciated.
Dani Chankhour
Are you seeing the Buttons Floater in Dreamweaver?
Yes, I see the floating buttons area pop up. If I try to use it the message states that I have not input the API Signature information, so I try to do that and the same problem occurs, I click Finish but nothing happens. Could it be a defect in the extension that I downloaded? Should I remove and erase this extension and try the download again?
Dani Chankhour
You can try that, but if you are seeing the floater i don't think that is an issue.
do you have Dreamweaver site defined?
Yes, I do have Dreamweaver site defined. I've been using Dreamweaver for quite some time now and wanted to use the Paypal buttons as it would speed up my development.
Dani Chankhour
I have opened a support ticket to further assist your with this issue:
vshad420395
I'm having the same issue, I have a PayPal business account and once I copy and paste the API information into the three fields and hit the finish button, nothing happens, as if the button is unresponsive, if anyone has any ideas let me know. Thanks
What version of Dreamweaver are you using? What OS?
vshad420395
must Amembat
I'm running Dreamweaver CS5 on Windows 7 x64.
