Figuring out if the user is logged in or not!?
Thread begun 12/06/2010 2:26 am by iamdan356160 | Last modified 12/06/2010 7:11 am by Jason Byrnes | 1568 views | 1 replies |
iamdan356160
I'm sure this is quite a simple question... but I can't seem to get my head round the issue...
I simply want to be a able to display 'Login' if the user is NOT logged in and 'Log Out' if the user is logged in. This is the code that I've created...
<?php if (isset($_SESSION['User_ID'])) {
echo '<a href="/Users_LogOut.php">Log Out</a>';
} else {
echo '<a href="/login.php">Login</a>';
Whether I'm logged in or out, I'm always seeing 'Login'. Any ideas why?
Kind Regards,
Dan
if the user is logged in, the User_ID session variable should have a value.
the issue you are having is that you chjecking to see if the session is set. The session could very well be set but have a blank value. you need to check both conditions, is set AND not equal to a blank string:
if (isset($_SESSION['User_ID']) && $_SESSION['User_ID'] != "") {
