Have to submit page twice to update table
Thread begun 12/06/2010 1:50 am by acaciasd344844 | Last modified 12/06/2010 8:09 am by Jason Byrnes | 2230 views | 3 replies |
acaciasd344844
I am not sure whats going on here as I have used this function many times. When I try to update multiple rows using dataassist(2.0.6) I have to use a submit button and click it twice before the table is populated. This appears to be the only way the function works. It uses the Post method, but if I set it to Default, I get the following error...
Request-URI Too Large
The requested URL's length exceeds the capacity limit for this server.
Apache/2.2.14 (Win32) DAV/2 mod_ssl/2.2.14 OpenSSL/0.9.8l mod_autoindex_color PHP/5.3.1 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 Server at localhost Port 80
In previous versions of data assist non of this occurred I really don't know what's happening.
Normally, I would be able to go to the page and have it update automatically or simply get the customer to click a continue button and this would update the database. I Have added the page code, so you can see what is going on...
<?php require_once('../Connections/midas0001.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_midas0001, $midas0001);
$query_Recordsetupdatemultiple = "SELECT distinct(customerid), IF(Count(payments.paymentid) >= '1' and payments.code='PP', Count(payments.code='PP'), '') as orgreminderno, IF(Count(payments.paymentid) = '1' and payments.code='PP','Send Invoice','') as invoice, IF( Count(payments.paymentid) >'1' and payments.code='PP', 'Pre-Payments Left','') as invoice2, customerid, paymentid, reminderno FROM payments WHERE payments.stampoperative>= Date(now()) and payments.code='PP' GROUP BY payments.customerid";
$Recordsetupdatemultiple = mysql_query($query_Recordsetupdatemultiple, $midas0001) or die(mysql_error());
$row_Recordsetupdatemultiple = mysql_fetch_assoc($Recordsetupdatemultiple);
$totalRows_Recordsetupdatemultiple = mysql_num_rows($Recordsetupdatemultiple);
$query_Recordsetupdatecustomers = "SELECT * FROM customers";
$Recordsetupdatecustomers = mysql_query($query_Recordsetupdatecustomers, $midas0001) or die(mysql_error());
$row_Recordsetupdatecustomers = mysql_fetch_assoc($Recordsetupdatecustomers);
$totalRows_Recordsetupdatecustomers = mysql_num_rows($Recordsetupdatecustomers);
$query_Recordset1 = "SELECT reminderno FROM customers";
$Recordset1 = mysql_query($query_Recordset1, $midas0001) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);?>
// WA DataAssist Multiple Updates
if (isset($_POST["Update"])) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_customerid");
$WA_connection = $midas0001;
$WA_table = "payments";
$WA_redirectURL = "";
$WA_keepQueryString = true;
$WA_indexField = "customerid";
$WA_fieldNamesStr = "reminderno";
$WA_columnTypesStr = "none,none,NULL";
$WA_connectionDB = $database_midas0001;
$WA_multipleUpdateCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleUpdateCounter)) {
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("orgreminderno", $WA_multipleUpdateCounter) ."";
$WA_where_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleUpdateCounter);
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
$WA_multipleUpdateCounter++;
if ($WA_redirectURL != "") {
?><?php
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "-1";
<head>
</head>
<body>
<form action="" name="form1" id="form1">
<p>
<label></label>
<label>
<input type="submit" name="Update" id="Update" value="Update" />
</label>
<a href="test2.php">next</a></p>
<table width="200" border="1">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_Recordsetupdatemultiple){
<tr>
<td nowrap="nowrap"><label>
<input type="hidden" name="WADA_RepeatID_customerid_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_customerid_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_Recordsetupdatemultiple["customerid"]; ?>" />
<input name="customerid_<?php echo $RepeatSelectionCounter_1; ?>" type="text" id="customerid_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_Recordsetupdatemultiple['customerid']; ?>" />
</label></td>
<td><label>
<input name="orgreminderno_<?php echo $RepeatSelectionCounter_1; ?>" type="text" id="orgreminderno_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_Recordsetupdatemultiple['orgreminderno']; ?>" />
</label></td>
<td><label>
<input name="reminderno_<?php echo $RepeatSelectionCounter_1; ?>" type="text" id="reminderno_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_Recordsetupdatemultiple['reminderno']; ?>" />
</label></td>
<td><label></label></td>
<td>
<label>
<input name="paymentid_<?php echo $RepeatSelectionCounter_1; ?>" type="text" id="paymentid_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_Recordsetupdatemultiple['paymentid']; ?>" />
</label></td>
<td>&nbsp;</td>
</tr>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_Recordsetupdatemultiple && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
</table>
<p>&nbsp;</p>
<p>&nbsp;</p>
</form>
</body>
</html>
mysql_free_result($Recordsetupdatemultiple);
mysql_free_result($Recordsetupdatecustomers);
mysql_free_result($Recordset1);
I hope you can help?
John
the problem is code order.
the recordset is created before the update record code.
so when the update button is pressed, the record is created with the old data, then the data is updated, then the page displays.
reorder the code so that the recordset code is after the update record code, this way the record will be updated, then the recordset will be created.
acaciasd344844
THanx
Cheers Jason,
I got it working
Thanks again
glad to hear it is working.
