Pro Maps - Driving Directions with Form Fields
Thread begun 12/05/2010 6:59 pm by mgkoll418996 | Last modified 12/06/2010 7:05 am by Jason Byrnes | 1875 views | 1 replies |
mgkoll418996
First time have used the extension. Finally got the map showing well, now working on getting driving directions to the default location using forms.
Everything goes fine until Entering Driving Directions Information. The lightning bolt boxes are not highlighted so I can enter them and bind the form fields.
Is there something I need to do differently up front to allow binding the form boxes?
www.hairstylebysam.com
To use dynamic data, you will need to add the map to a dynamic file type.
if the page you are adding the map to has the extension .html it is a static page that does not allow dynamic data. your page must have a dynamic extension like .php.
you will also need to have your Dreamweaver site configured for dynamic development.
see the "Defining a Dynamic Site in Dreamweaver" tutorial on the learning resources page:
resources.php
