blank page
Thread begun 12/03/2010 10:54 am by i.edwards384429 | Last modified 12/06/2010 7:20 am by Jason Byrnes | 4509 views | 8 replies |
i.edwards384429
blank page
Hi
using data assist and security assist I have created the normal pages via the wizard
On my local test server (WAMP) if I run Admin.php enter incorrect details I am diverted to the email password reminder page.
If I enter a valid username and password I am sent to admin_search.php
So locally all works perfectly
I deleted all remote files and uploaded fresh copies so everything is the same on the live server.
Now if I go to Admin.php on my live server put in an incorrect password then as expected I am sent to the email pw page.
If I enter a correct username/password I'm sent to admin_search.php The address bar gives the correct address but the page is blank and if I view source there is none.
I've attached the search file in case the code is wrong.
The site is not live so Admin.php and username/password of ian and ian shows the blank page
would appreciate any ideas
thanks
Ian
when a php page displays blank it means a php error has occurred, but error reporting is turned off.
add the following code at line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
neilo
Hi Ian & Jason,
When I go to Admin.php and enter the test username and password, instead of being directed to admin_search.php, I get a download window asking what I want to do with the file, - open it with a program, or save the file.
This is the behaviour I would expect to see if PHP was disabled somehow, but as your other PHP page reads OK, it seems strange that this happens. I haven't seen this before. Maybe it's a PHP version issue?
neilo, that behavior will also happpen if there is a php error on the page.
both the blank screen and the downloading page point to php level errors.
neilo
Thanks for the info, Jason. I hadn't come across that before!
i.edwards384429
update
Hi
Thanks one and all, even more confused now
If I type in
Admin.php
I do see a login page.
I'm using the admin section for an admin backend and the normal search
boats_search.php displays perfectly on my web server so I'm assuming the php version is OK
lastly I added the error code
error_reporting(E_ALL);
and I still see a blank screen and no code in the view source screen.
What really puzzles me is it works on my wamp server
all good fun
cheers
Ian
if the error reporting code is not showing the error, then you will need to contact the host to look into the servers error logs to see what is going wrong.
until we have an error message, there no telling what the problem is.
i.edwards384429
update- egg on face
Hi
found problem was all due to a typo in file name.
The code was re directing to admin_search.php
where as the page was actually called admin_Search.php and as my web server is unix......
still dont know why I got a blank page instead of a 404 but at least the problem is solved.
Make mental note - check file names in future
cheers
Ian
OK, glad to hear the problem is solved.
