progress bar
Thread begun 12/03/2010 4:44 am by CraigR | Last modified 12/03/2010 8:25 am by Jason Byrnes | 2632 views | 3 replies |
CraigRBeta Tester
progress bar
i have a friend who is doing some fundraising.
they would like to display a 'thermometer' progress chart in their site.
i have had a look at dynamic web charts, to make a single column bar chart with the hope i could use this and overlay an image to appear as the thermometer 'bulb'.
Does this seem feasible ?
the first issue I have come across is setting a scale with a single input.
if the target is 10000 and the current value is 500, i want to show a tall graph, buit with a small bar.
I can't see how to do this
go into the xml editor to edit the chart xml, and set a max property for the yaxis.
<yaxis max="1000" color="#767a7f" gridcolor="#888d93">
CraigRBeta Tester
thanks Jason. That helps.
Is there an easy way to overlay a graphic.
i tried wrapping a div class with a background image around the flash, but it always sits behind the flash.
i can't seem to edit the flash file.
is there an easy way to position a background image using the xml with precision ?
you will need to edit the flash objects wmode property to transparent:
<param name="wmode" value="transparant" />
and probably set the flash objectrs z-index to something very small.
Then using absolute positioning on the image, you can position it over the flash object.
