Error messages everywhere!
Thread begun 12/02/2010 5:58 pm by BruceT | Last modified 9/12/2014 11:49 am by agmichaca | 3640 views | 4 replies |
BruceT
I've just finished my first form with CSS Form Builder and so far, I'm NOT impressed.
Here are the error messages that flood my screen when I attempt to submit the form:
Warning: mkdir() [function.mkdir]: Permission denied in /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php on line 30
Warning: mkdir() [function.mkdir]: No such file or directory in /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php on line 30
Warning: move_uploaded_file(/home/content/m/e/m/memoriesadmin/html/file:///Macintosh HD/Applications/MAMP/htdocs/memoriesoncanvas/b57738955879626658a231e00ae34f0c_tmp.jpg) [function.move-uploaded-file]: failed to open stream: No such file or directory in /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/tmp/phprSrSUw' to '/home/content/m/e/m/memoriesadmin/html/file:///Macintosh HD/Applications/MAMP/htdocs/memoriesoncanvas/b57738955879626658a231e00ae34f0c_tmp.jpg' in /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php on line 96
Warning: copy(/home/content/m/e/m/memoriesadmin/html/file:///Macintosh HD/Applications/MAMP/htdocs/memoriesoncanvas/b57738955879626658a231e00ae34f0c_tmp.jpg) [function.copy]: failed to open stream: No such file or directory in /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php on line 98
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php:30) in /home/content/m/e/m/memoriesadmin/html/submission.php on line 105
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php:30) in /home/content/m/e/m/memoriesadmin/html/submission.php on line 105
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php:30) in /home/content/m/e/m/memoriesadmin/html/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php:30) in /home/content/m/e/m/memoriesadmin/html/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php:30) in /home/content/m/e/m/memoriesadmin/html/submission.php on line 135
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/m/e/m/memoriesadmin/html/webassist/file_manipulation/helperphp.php:30) in /home/content/m/e/m/memoriesadmin/html/submission.php on line 135
The first five error messages are causing the other ones.
The error messages mean that the upload folder you specified in the file up load portion does not exist, and the server does not grant high enough privileges for it to be created.
You will need to create the file upload folder manually and make sure that it has read and write privileges so that uploaded files can be written to it.
agmichaca
Kind of privileges
I have the same problem.
What kind of privilages do a folder need?
I am trying to create folder above webroot, I have tried with folder with 0777 and 1777.
I have apache dso the group and owner are accountuser:accountuser.
777 should be fine, if it is not working with those permissions assigned, you should contact the host for help.
agmichaca
Thank you!
