HTML editor Images not working
Thread begun 12/02/2010 4:05 pm by rockinghansen55333054 | Last modified 12/03/2010 9:04 am by Jason Byrnes | 1529 views | 1 replies |
When i go to the admin section of the website im designing and i select the page i want to edit. I have it echo data into the editor this way the user can edit the HTML code from the db.
So here is where the problem comes in.
say you came along and wanted to add the google image to your home page. you would select the home page then it would display the home page data. You then would click on the image button in the HTML editor. then you would put the URL of the image in this case google-logo_2.jpg into the URL section.
Then to save the data you click submit.
On the next page you will see the data that is in the db in. when you see it on this page the image is not shown. If you view the source of the site the image will show up like this
It should show up like this google-logo_2.jpg because its an external image.
Let me know if i need to clarify better.
Enter the address directly into the URL section on the image properties tab, see the enclosed screes shot.
