CMS Error
Thread begun 12/02/2010 1:31 pm by Larry321390 | Last modified 12/21/2010 7:56 am by Larry321390 | 6872 views | 14 replies |
Larry321390
CMS Error
I added another content with the green plus at the topof the screen.
It was to add cms to the opening page of the web site.
My file structure is
The root is: home/eriss/public_html/
index.php which is the opening page that I created and is in the root. It links to the power store files in a sub folder called PStore4 where all the power store files are stored.
I added the new content page as indicate and copy the code from the index.php file thta I created in dreamweaver and placed the code fro the dreamweaver file into add content box I created cms. i. e. logo menu
I got the developer notes for each added content and placed it in the dreamweaver file. This is the first one
<?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Opening Web Page', 'LOGO', false); ?>
I saved the my index.php file to the server root.
When I call the site to the broswer this is the error I got:
Fatal error: Call to undefined function wa_getcmscontent() in /home/eriss/public_html/index.php on line 47
line 47 is where i placed the Developer note
I supect it is a path problem but do not know where to look and do not want to change a path and have the rest of the store not work.
Please Advise.
Larry
make sure your page has the require code for the webassist/cms/cms.php page on it:
<?php require_once( "webassist/cms/cms.php" ); ?>
Larry321390
I put the code <?php require_once( "webassist/cms/cms.php" ); ?> on line 38
The next line is </head>
I got these messages:
Warning: require_once(webassist/cms/cms.php) [function.require-once]: failed to open stream: No such file or directory in /home/eriss/public_html/index.php on line 38
Fatal error: require_once() [function.require]: Failed opening required 'webassist/cms/cms.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/eriss/public_html/index.php on line 38
Please advise.
Thamks,
Larry
where are the power store files uploaded on your server you will need to adjust the path for the cms.php include file to point to the root of the power store files.
Larry321390
Making Progress but stumped again. What do you suggest next. Thanks Larry
I added the PStore4 which is the directory all the power store files are stored in.
I get these messages which tells me I'm not connection to the database.
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/eriss/public_html/PStore4/webassist/cms/cms.php on line 22
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/eriss/public_html/PStore4/webassist/cms/cms.php on line 30
/home/eriss/public_html/ is the root for web sites
add the connection require once at line 1:
<?php require_once('PStore4/Connections/PowerStoreConnection.php'); ?>
Larry321390
I tried that and got the same errors:
Warning: Unknown: open(/tmp/sess_f4223768aeb45b8a140c3c45987e7adc, O_RDWR) failed: Permission denied (13) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/tmp) in Unknown on line 0
What should I try next? I am building two power stores and the same error it showing on both.
Thanks for the help
Larry
please send a copy of the page.
Larry321390
code is attached
I have attached the code.
Larry
in the file you sent, you have not made the code change i suggested, change line 1:
<?php require_once( "PStore4/webassist/cms/cms.php" ); ?>
