DigitalFilePro2 doesnt creat folder or files
Thread begun 12/02/2010 9:59 am by virtualbr | Last modified 12/03/2010 6:26 am by Jason Byrnes | 3565 views | 5 replies |
virtualbr
Hello.
I have a CS3, with many WA plugins.
I created a admin page with DA Wizard, all forms and files were generated automatically.
One of my forms had a field which i changed to a File Field.
Then i proceeded to adding DigitalFilePro 2 upload option.
However, at the end of the configurations screens, no files are generated and the page points to a file which isnt there.
"../../WA_DigitalFilePro/HelperPHP.php"
Also, on my Server Behaviors Panel I see a Upload Files (file) (prior version)
I wonder what that prior version means, because I have just downloaded and instaled all extensions once again from the WA site, in order to try to fix this error last night.
Can anyone help me on this? I dont know why the files dont get generated in the DFP2.
Thank you so much.
Do you also have Universal Email 4 or CSS Form builder 2 installed?
If you have either of those extensions installed, you should install Digital File pro 2, since it is bundled in either of those 2 extensions.
virtualbr
Hello!
I have Universal Email 4 installed.
I have CSS form Builder Installed.
And I have Digital File Pro 2 installed.
Interesting you mention this, because when i lauched Digital File Pro 2, it asked for the serial number of Universal mail instead of Digital File Pro 2.
Anyways, I have all of them installed, and this problem still remains.
Could it be because the page i intend to use DFP2 is inside 2 folders? foler/folder/page.php
I will try a test with all files on root folder.
Thank you very much for your help.
Any other ideas are very much apreciated.
Thank you.
What version of CSS Form Builder?
If it is CSS Form Builder 2, you should not install either EU4 or DFP 2
Both of those extensions are built into CSS Formbuilder 2.
If it is CSS Form Builder 1, then keep UE4 installed, but do not install DFP 2, it is built into UE4.
virtualbr
Thank you very very much!
I would have taken a very long time to figure this one out. Although now it seems obvious to me.
I have uninstaled DFP2, i kept UE4, and i have css form builder 1.
So now, after I made my first setup test, all worked as expected.
Thanks a lot! Very much apreciated help.
Issue solved in a few hours.
Great, glad to hear it is working.
