Site Sculptor - white pages
Thread begun 12/02/2010 3:59 am by kenneth418049 | Last modified 12/02/2010 7:35 am by Jason Byrnes | 1648 views | 1 replies |
kenneth418049
After installing a standard template from Site Sculptor and following the guide to completion no pages load.
I did the 4 steps from the install folder, no problems seen.
But after the (page)4.php nothing happends.
When trying to acess any of the installation folders or any other page, the page is just white.
Looking at all the files in CS5, nothing seems wrong.
All the require once ( as read on other forums are intact. )
( <?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
<?php require_once( "../WA_Globals/WA_Globals.php" ); ?>
<?php require_once( "../WA_CMS/WA_CMS.php" ); ?>
<?php require_once('../Connections/PowerCMSConnection.php'); ?>
if (!WA_Auth_RulePasses("Administrator")){
WA_Auth_RestrictAccess("users_login.php");
But as i said, the pages are white, and nothing loads.
What can i do? (even tried to remove the installation folder as some databases needs that for security)
/Ken
In addition; i used site-sculptor_gsg.php
Point 4 (content management) dont happen!
Once you have completed the Installation Wizard, you will be taken to the content management system for you to start modifying the content that is on the pages of your site.
even the (Returning to the content management feature
You can return to your content management feature at any time after you have installed everything.
1. Open your preferred browser (Internet Explorer, Firefox, etc.)
2. In the address bar, enter the URL for where you just uploaded your files and append /admin.
For example, mysite.com/admin.)
a blank page means that a php error is occurring but error reporting is turned off.
Add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL):
