Checkbox group not writing to database
Thread begun 12/02/2010 12:32 am by FrankJay | Last modified 12/07/2010 7:49 am by Jason Byrnes | 3779 views | 5 replies |
FrankJay
I have created a form using CSS form builder. It is made up of a few radio groups and a few checkbox groups. The information is written to a database when the form is submitted. All the radio group information is correctly written to the database. I am having a problem with the checkbox groups as the information is not stored to the database.
multiple_cb.php
Please help me with detailed fix.
A checkbox group creates an array of the values that where selected.
The array needs to be converted to a comma separated list before is can be inserted to the database.
add the following code at line 1 of your page:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
        if(
is_array($_POST[$key])) $_POST[$key] = implode(", "$_POST[$key]);
this uses the implose function to convert the array to a comma separated list.
FrankJay
Still not working
I have inserted the code as suggested. Still not writing to db.
Attached zip file of page in question showing additions. Kindly check page code for errors.
Much appreciated, Thanks Jason
change line 43:
$WA_fieldValuesStr = "".((isset($_POST["AgeGroup"]))?$_POST["AgeGroup"]:"")  ."" . "|" . "".((isset($_POST["GenderGroup"]))?$_POST["GenderGroup"]:"")  ."" . "|" . "".((isset($_POST["EthnicityGroup"]))?$_POST["EthnicityGroup"]:"")  ."" . "|" . "".((isset($_POST["CentreQuestionGroup[]"]))?$_POST["CentreQuestionGroup[]"]:"")  ."" . "|" . "".((isset($_POST["CentreComments"]))?$_POST["CentreComments"]:"")  ."" . "|" . "".((isset($_POST["AreaQuestionGroup[]"]))?$_POST["AreaQuestionGroup[]"]:"")  ."" . "|" . "".((isset($_POST["AreaComments"]))?$_POST["AreaComments"]:"")  ."" . "|" . "".((isset($_POST["Promotion[]"]))?$_POST["Promotion[]"]:"")  ."" . "|" . "".((isset($_POST["KeysComment"]))?$_POST["KeysComment"]:"")  ."" . "|" . "".((isset($_POST["GTAComment"]))?$_POST["GTAComment"]:"")  ."" . "|" . "".((isset($_POST["MeetComment"]))?$_POST["MeetComment"]:"")  ."";
$WA_fieldValuesStr = "".((isset($_POST["AgeGroup"]))?$_POST["AgeGroup"]:"")  ."" . "|" . "".((isset($_POST["GenderGroup"]))?$_POST["GenderGroup"]:"")  ."" . "|" . "".((isset($_POST["EthnicityGroup"]))?$_POST["EthnicityGroup"]:"")  ."" . "|" . "".((isset($_POST["CentreQuestionGroup"]))?$_POST["CentreQuestionGroup"]:"")  ."" . "|" . "".((isset($_POST["CentreComments"]))?$_POST["CentreComments"]:"")  ."" . "|" . "".((isset($_POST["AreaQuestionGroup"]))?$_POST["AreaQuestionGroup"]:"")  ."" . "|" . "".((isset($_POST["AreaComments"]))?$_POST["AreaComments"]:"")  ."" . "|" . "".((isset($_POST["Promotion"]))?$_POST["Promotion"]:"")  ."" . "|" . "".((isset($_POST["KeysComment"]))?$_POST["KeysComment"]:"")  ."" . "|" . "".((isset($_POST["GTAComment"]))?$_POST["GTAComment"]:"")  ."" . "|" . "".((isset($_POST["MeetComment"]))?$_POST["MeetComment"]:"")  ."";
FrankJay
Now Working
Suggested code changes to line 43 has been implemented. Submitted checkbox group information is now successfully written and stored to db. Thanks for the help Jason.
you're welcome.
