Duplicate Database Entries
Thread begun 12/01/2010 8:24 am by msbannister373603 | Last modified 12/03/2010 11:32 am by Jason Byrnes | 8306 views | 9 replies |
msbannister373603
I need help getting the server validation to work. I'm simply trying stop my database from accepting duplicate entries. The checked entry is not a unique key and the dreamweaver check username behavior doesn't work. Please advise. I'm using the server validation with Validation toolkit and I've followed the advice from the posts on this forum to no avail. The code is below:
<?php require_once('../../Connections/basketball.php'); ?>
<?php require_once("../../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_girls_players = "-1";
if (isset($_GET['name'])) {
$colname_girls_players = (get_magic_quotes_gpc()) ? $_GET['name'] : addslashes($_GET['name']);
mysql_select_db($database_basketball, $basketball);
$query_girls_players = sprintf("SELECT * FROM girls_players WHERE name = %s", GetSQLValueString($colname_girls_players, "text"));
$girls_players = mysql_query($query_girls_players, $basketball) or die(mysql_error());
$row_girls_players = mysql_fetch_assoc($girls_players);
$totalRows_girls_players = mysql_num_rows($girls_players);?>
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "../validation/player_exists.html";
$_SESSION['WAVT_girlsplayersInsert_626_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM($totalrows_girls_players['name'] . "",-1,0,"",",.",false,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"girlsplayersInsert_626");
// WA Application Builder Insert
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $basketball;
$WA_table = "girls_players";
$WA_sessionName = "girls_players_players_id";
$WA_redirectURL = "girls_players_sResults.php";
$WA_keepQueryString = false;
$WA_indexField = "players_id";
$WA_fieldNamesStr = "name";
$WA_fieldValuesStr = "".((isset($_POST["name"]))?$_POST["name"]:"") ."";
$WA_columnTypesStr = "',none,''";
$WA_connectionDB = $database_basketball;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/home_admin.dwt" codeOutsideHTMLIsLocked="false" -->
<head>
<title>SCHS Basketball Database</title>
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
</script>
<script type="text/javascript" src="../../CSSMenuWriter/cssmw/menu.js"></script><!--[if lte IE 6]>
<style type="text/css" media="all">
@import url("CSSMenuWriter/cssmw/menu_ie.css");
</style>
<![endif]-->
<link href="../../css/admin.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="wrapper">
<div id="header">
</div>
<div id="sidebar"> </div>
<div id="main_content">
<div id="nav"><a href="../admin_home.php"><img src="../../WA_DataAssist/images/Nautica/Traditional_home.gif" name="home" width="83" height="27" border="0" id="home" /></a><img src="../../WA_DataAssist/images/Nautica/Traditional_Logout.gif" width="83" height="27" border="0" /></div>
<!-- InstanceBeginEditable name="Title" -->
<div id="page_title">
<h1>Add Girls Players</h1>
</div>
<!-- InstanceEndEditable -->
<div id="data"><!-- InstanceBeginEditable name="main_content" -->
<div class="WADAInsertContainer">
<form method="POST" name="WADAInsertForm" id="WADAInsertForm">
<div class="move_left">Insert Girls Player:</div>
<div class="WADAHorizLine"><img src="../../WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table border="0" cellpadding="0" cellspacing="10" class="WADADataTable" id="tb_insert">
<tr>
<th class="WADADataTableHeader">Player's Name</th>
<td class="WADADataTableCell"><input type="text" name="name" id="name" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="../../WA_DataAssist/images/Nautica/Traditional_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="../admin_home.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../../WA_DataAssist/images/Nautica/Traditional_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
<!-- InstanceEndEditable --></div>
</div><!--end main_content-->
<div id="footer">
<p>2010 &copy; One Twelve Sports | contact us | about us | privacy rights | terms and conditions | site by Mike Bannister Media</p>
</div>
</div>
<!--end wrapper-->
<div id="apDiv1"></div>
</body>
<!-- InstanceEnd --></html>
mysql_free_result($girls_players);
the recordset is filtering on the name Query sting variable instead of the name From post.
Set the filtering up as:
'name' '='
'Form variable' 'name'
msbannister373603
Not Working
I tried and changed to form variable. Still not working. Any other suggestions
change:
$WAFV_Errors .= WAValidateNM($totalrows_girls_players . "",-1,0,"",",.",false,1);
msbannister373603
Sorry still not working. It still inserts the same name. Next suggestion? Thx for helping
case sensitivity. the line that sets the total rows variable is:
you need to use the same case in the server validations.
change:
$WAFV_Errors .= WAValidateNM($totalRows_girls_players . "",-1,0,"",",.",false,1);
msbannister373603
Thanks got it working! You're the man!
you're welcome.
msbannister373603
Duplicate dbase entries with multiple insert behavior
Thanks for help with the single insert form. However, I can't figure out what I'm doing wrong trying to get the validation to work with the multiple insert behavior. Thanks
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
if (isset($_POST['name'])) {
$colname_girls_players = (get_magic_quotes_gpc()) ? $_POST['name'] : addslashes($_POST['name']);
$WAFV_Errors = "";
<?php require_once('../../Connections/basketball.php');?>
// WA DataAssist Multiple Inserts
$WA_loopedFields = array("name");
$WA_insertIfNotBlank = "name";
$WA_multipleInsertCounter = 0;
while (WA_AB_checkMultiInsertLoopedFieldsExist($WA_loopedFields, $WA_multipleInsertCounter)) {
if ($WA_insertIfNotBlank == "" || WA_AB_checkLoopedFieldsNotBlank(array($WA_insertIfNotBlank), $WA_multipleInsertCounter)) {
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("name", $WA_multipleInsertCounter) ."";
$WA_multipleInsertCounter++;
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = true;
$RepeatSelectionCounter_1_Iterations = "20";
this sort of validation is not supported in a multiple insert behavior.
with multiple insert the form elements are dynamically named.
This will require extensive unsupported hand coding to make work.
