Insert Record not catching new File Name
Thread begun 12/01/2010 8:22 am by mrobben375515 | Last modified 12/02/2010 7:51 am by Jason Byrnes | 2684 views | 4 replies |
mrobben375515
I'm using Digital File Pro to create a photo upload form on two pages. The upload works fine, but inserting the file name into the database when files have the same name isn't working quite right.
On the first page the file names are stored as session variables. On the second page there's a second form with more upload fields, and the file names from these and the file names from the previous page (stored in session variables) are inserted into the database. Everything works fine until there's identical file names. I set Digital File Pro to rename the new files with an extension, but this is not reflected in the database. Can I get the renamed file names to show up instead? I've attached the file, thanks
mrobben375515
Sorry, I forgot the first file. It's attached here
Your set session value behaviors are getting the file name from the form collection.
you need to use the Server FileName Binding From the WA_Uploaded Files (Field Name) group instead.
also the set session value behaviors will need to be moved after the file upload behaviors in the code.
mrobben375515
I knew there was somethin I didn't choose right. Thank you, it works perfect now
you're welcome.
