Downloading Files Using Absolute File Paths in Universal Email
Thread begun 12/01/2010 8:00 am by shane267050 | Last modified 12/01/2010 9:59 am by Jason Byrnes | 2007 views | 3 replies |
shane267050
In universal email I'm only able to trigger the download if the path is ../../MyRepository
For security I would like to use the directory path outside the web root.
For Example use: /Volumes/A4/MyRespository
Here is an example of what works:
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult1");
if(($_SESSION['DBbkup'] != "")){
$downloadname = $_SESSION['DBbkup'];
$dataroot = "../../MyRespository/";
$bkdir = $dataroot . 'backup/';
WA_DFP_DownloadFile("WA_DownloadResult1", "$bkdir", "$downloadname", "[FileName]", false, false, false, "", "", "", "");
Here is an example of what doesn't work:
**A note for troubleshooting: I can upload using the path $dataroot and $bkdir below**
I believe the helper file is stripping something, but not sure what or how to correct its behavior.
$dataroot = "/Volumes/A4/MyRespository/";
Thank you.
Universal Email will only take the relative path.
This does not mean that the a relative path cannot be used to go outside of the web root.
say for example the webroot is:
/Volumes/A4/htdocs/
and the page is at
/Volumes/A4/htdocs/mypage.php
the relative path:
../MyRepository
will get you to the MyRepository folder outside of the root.
shane267050
Thank you for help and quick reply!!
you're welcome.
