calculation on date
Thread begun 11/30/2010 3:05 pm by pbrihat283410 | Last modified 12/01/2010 7:29 am by pbrihat283410 | 2679 views | 4 replies |
pbrihat283410
calculation on date
Hi
Using the ecart object calculation panel, is it possible to make a calculation on date. I am trying to substract 30 days from date column value but its returns … nothing
Pierre
Dani Chankhour
This depends on how you are storing the Date format. What date format are you using to store the date in your database?
pbrihat283410
date format
hi,
dates were store as varchar, stupid off course. I have changed it to date and now a value is returned but it's a 4 digit value !! What am i missing here ?
Pierre
Dani Chankhour
OK, i have done some more testing and in order to accomplish this we need to use the php timestamp to be able to subtract the 30 days. first, please update your date column to use the timestamp. This will store the date in the following format:
2010-11-30 17:47:32
Then your calculation should be something similar to this:
strtotime([dateColumn1]) - (30*24*60*60)
basically we convert the date to a timestamp and then subtract 30 days.
let me know if you have any questions.
pbrihat283410
Thanks you've put me on the right track. Your calculation works just fine. No need to change to column to timestamp though. It works with date. After that it's just a matter of reformatting the timestamp to appear as regular date.
Pierre
