Power Gallery 1.2.0 file won't extract correctly
Thread begun 11/30/2010 5:54 am by kbettenc296716 | Last modified 12/06/2010 3:54 pm by Dani Chankhour | 2882 views | 5 replies |
kbettenc296716
When I try to extract the Power Gallery 1.2.0, it continually indicates that the folders are exist as files and only gives me 2 options - Try Again and Skip. I have tried this several times with no difference.
Dani Chankhour
Are you on Windows or MAC?
Try saving the zip to a different place( your desktop) and try to extract it from there.
kbettenc296716
Update
I am using a PC/Vista. I saved the file to my desktop, and got the same error. See attached.
Dani Chankhour
Thanks, i can reproduce the issue on Vista only. I have logged a bug in our bug base and we will try to fix the issue as soon as possible.
Meanwhile, try using 7zip
www.7-zip.org/
which should be able to extract the zips correctly.
kbettenc296716
That works a treat.
Dani Chankhour
A new version of PowerGallery 1.2.1 has been released and it should be in your Download Center. This new version should fix the issue you were running into with extracting the zip.
Let me know if you still experiencing the issue with this new dot release.
