Begining to look like full refund - nothing but errors
Thread begun 11/29/2010 10:32 pm by CBNisp | Last modified 11/30/2010 10:47 am by Jason Byrnes | 5244 views | 9 replies |
CBNisp
I just purchased the super suite.
Everything thing i've done so far is nothing but errors.
Security Assist Wizzard can't even build a set of working pages.
I've used many plugins for years, never seen (about to say junk) I'm just pissed off because I been at this over 16 hours without sleep.
What gets me, as I walk through wizzard, and select the unique field as email, and set the user login as email - the wizzard generate code and has USERNAME as login field, the database dont even have a username. The login form etc is set for username. I'm like, where the heck did it get that from?
RD
what are the errors you are getting. I will be happy to help you out, but need to know the specifics of the errors.
Also, What version of Dreamweaver are you using?
What is your OS?
Can you send copies of the pages so I can examine the code?
CBNisp
Ok, I'm attaching pages
First,
after registration it does not redirect to login but it does insert the record in mysql. Trying to login gives nothing but blank pages.
Dreamweaver CS5
Mac OSX Snow 10.6.5
***EDIT
Let me add error logging in htaccess and see what they say
I zipped the public_html so you see the files security assist generated
Richard
CBNisp
Files Didn't attach
Try it again
Forgive me for being so mad...
But here id what I finally did...
I just created a simple database
u_id
u_username
u_email
u_password
And let security assist wizzard generate the pages and that didn't work.
Richard
Most likely the entire site is creating a zip file that is to big, please send only the registration and the login page for now in a zip archive.
when a blank page displays, it is because a php error is occurring, we will need to know the text of the error to debug it.
to get the error text add the following code at line 1:
error_reporting
(E_ALL);
CBNisp
Zip File
Here ya go, Try again...
Thank you for the quick response, i've been at this since I purchased sunday until I finally crashed about 7am this morning.
Please help me get this fixed so I can be on my way because I have client projects sitting that I got to get back to...
Thanks,
Richard
ok, the errors are being caused by the way the helpers are being attached to the page:
<?php virtual('/Connections/myLink.php');?>
<?php virtual( "/WA_SecurityAssist/Helper_PHP.php" ); ?>
using the virtual function is causing the headers already sent error.
this is a DW Site Settings issue.
In the Dreamweaver Site Settings, there is an option on the Local Info Tab for "Create Links Relative To". If you set this option to "Site" It causes Dreamweaver to attach helper files using the virtual function which is only supported in certain server environments, where it is supported, it causes the headers already sent.
Set that option to "Document" instead, this causes Dreamweaver to use the require_once function instead, which does not generate the headers already sent error.
CBNisp
Looks like it fixes it :)
Hey,
I regenerated the files and each page works!
I guess I will have to set paths by hand.
Thanks!
omg, something so simple as a setting in dw - blahhh - what a headache this caused me :(
You guys need to document this in HUGE RED WARNING
Richard
CBNisp
One last question
I'm trying to get to the digital goods store...
What are my steps?
Get the security assist working with user login/profile first?
Then start with the ecommerce tutorial?
Richard
ok glad to hear it is working.
This issue does not effect only WebAssist extensions, the same issue would occur when creating a standard recordset.
