Confirm Page
Thread begun 11/29/2010 7:01 pm by ecologictech417149 | Last modified 12/03/2010 12:07 pm by Jason Byrnes | 5577 views | 9 replies |
ecologictech417149
Confirm Page
When I go to test the page live... I will add a product to the cart and then proceed to check out. I will then fill in all of the personal billing and shipping information. When I click the checkout button it takes me to the confirm page and its blank....please help
a blank page means that a php error is occurring but error reporting is turned off.
add the following code at line 1 of the confirm page to turn error reporting on:
error_reporting
(E_ALL):
ecologictech417149
I added the code and still just a blank page....file is attached....
your page is missing the line to include the eCart object. you also added a blank line when adding the error reporting code.
change line 1 - 9:
error_reporting
(E_ALL):
<?php require_once('Connections/MyConnection.php'); ?>
$EcologicTechnologies
->GetContent();
error_reporting
(E_ALL):
<?php require_once('WA_eCart/EcologicTechnologies_PHP.php'); ?>
->GetContent();
ecologictech417149
I made the changes to the code for lines 1-9....same problem happening....new file attached...
please post a link where i can see the issue.
ecologictech417149
confirm.php
or if you want to go through the process I have some add to cart buttons added to a couple of products on the following page...you could add one to cart and checkout maybe..
fog_systems.php ...
my apologies, the error reporting code had a syntax error, it should be:
error_reporting
(E_ALL);
i had a colon (:) at the end of line 2 instead of a semi colon (;)
error_reporting(E_ALL);
ecologictech417149
i changed line 2 to a ; from a : like you said and Im still getting a blank page...please help
