Cannot add Date Picker/Captcha to a page based on a template
Thread begun 11/29/2010 5:36 pm by YellowCircleWeb | Last modified 11/30/2010 2:25 pm by Jason Byrnes | 4238 views | 5 replies |
YellowCircleWeb
Every time I try to use Form Toolkit on a page that's based on a Dreamweaver template I get the 'Making this change would require changing code that is locked by a template or a translator' error message, even though codeOutsideHTMLIsLocked is set to false in my template.
I use templates for all of my sites so if anyone can help me get round this problem that would be very much appreciated.
Russell CollinsBeta Tester
I have the same problem when trying to add datepicker to any dataassist pages
Regards
Russ
The error you are getting is a common one when working with templates in Dreamweaver.
There is no solid fix for the issue, but I have discovered a workaround. See the following thread for details:
showthread.php?t=4509
Thanks Jason,
Maybe better working it through framework instead of standard templates so it doesn't occur.
Russ
YellowCircleWeb
Yes I got it working when using the form as a plug-in with Framework Builder. Works quite nicely that way actually.
great, glad to hear it is working.
