Calling a JavaScript function from a menu item
Thread begun 11/29/2010 12:06 pm by markhaynes75235 | Last modified 12/14/2010 12:27 pm by markhaynes75235 | 7159 views | 4 replies |
markhaynes75235
I'm trying to implement some features using CSS MenuWriter but have found that in some instances, when using the menu item to call a script, the script does not run. One instance I have involves the CMS Font Sizer script. Instead of using hyperlinks, I want to use a CSS MenuWriter menu to call the script that resizes the text on the page. When I use simple hyperlinks the text resizes fine, but when I call the script from a menu it does not work. I've tried putting the script in the menu.php as well as in the same <div> and the <head> (shouldn't matter). So I'm wondering if anyone else has used CSS MenuWriter menus to call a JavaScript function.
The second instance involves IE (7 & 8). I'm calling the Shadowbox script to bring up a page in a shadowbox from a CSS MenuWriter menu. This works fine in all other browsers (Firefox, Safari, Google Chrome) but in IE the browser just navigates to the page, ignoring the rel="shadowbox....etc." in the <a> tag.
Thanks in advance for any insight as to how to fix this!
can you send a link where i could see the issue to debug the cause.
markhaynes75235
Hi Jason:
I've got the site set up on an internal system and I'm working with IT to see if I can share it out to authorized parties.
The script in live code view shows up like this:
// Change Text Size by Community MX
// Copyright 2007, All rights reserved
function CMXwriteCookie(n,i,t){
var ep="";if (t){d = new Date();d.setTime(d.getTime()+(t*86400000));
ep = "; expires="+d.toGMTString();}document.cookie = n+"="+i+ep+"; path=/";
window.location.href = window.location.href;
function CMXreadCookie(n){
eq = n+"=";ca = document.cookie.split(';');for(var i=0;i<ca.length;i++) {
c=ca[i];while (c.charAt(0)==' ') c = c.substring(1,c.length);
if (c.indexOf(eq) == 0) return c.substring(eq.length,c.length);}return null;
fSize=(CMXreadCookie('fSize') == null)?11:CMXreadCookie('fSize');
document.write('<style type=\"text/css\">');
document.write('.varText {font-size:'+fSize+'px;}');
document.write('<\/style>');
</script><style type="text/css">.varText {font-size:11px;}</style>
<script type="text/javascript" src="CSSMenuWriter/cssmw4/menu.js"></script>
<style type="text/css" media="all">
@import url("CSSMenuWriter/cssmw4/menu.css");
</style>
followed by a link to a stylesheet for the language translation module then I've set the body to use the class .varText:
<body class="varText">
and then nested inside wrapper and content <div> tags I've got the DIV with the menu:
<div id="services">
<div id="svcsContent">
<div id="textResize">
<ul class="level-0" id="cssmw4">
<li class="parent link"><a href="#" class="link">Choose a Font Size</a>
<ul class="level-1">
<li class="link"><a href="#" onclick="CMXwriteCookie('fSize',11,3650); return false;" style="font-size:11px" class="link">Small &gt; A</a></li>
<li class="link"><a href="#" onclick="CMXwriteCookie('fSize',14,3650); return false;" style="font-size:14px" class="link">Medium &gt; A</a></li>
<li class="link"><a href="#" onclick="CMXwriteCookie('fSize',18,3650); return false;" style="font-size:18px" class="link">Large &gt; A</a></li>
<li class="link"><a href="#" onclick="CMXwriteCookie('fSize',20,3650); return false;" style="font-size:20px" class="link">Larger &gt; A</a></li>
</ul>
</li>
</ul>
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw4.intializeMenu('cssmw4',{select_current: 0, orientation: 2}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw4.intializeMenu('cssmw4',{select_current: 0, orientation: 2}); }, true); }</script>
</div>
If you want to set a time when I can show it to you in a Connect session, I'll be happy to schedule the time so we can look at it. I greatly appreciate your help!
enthusiastically,
Mark
markhaynes75235
Calling a Javascript function from a menu item
In a support incident we found that the include script:
<script type="text/javascript" src="CSSMenuWriter/cssmw/menu.js"></script>
is only used in older browsers and was causing a conflict with other JavaScripts. Deleting that line fixed the problem - Jason noted that IE6 browsers may have problems with the menus when that script is not included.
I also found that IE 8 was showing errors in the include file menu.php. The last few lines on that page are javascript that call methods or functions in the include mentioned above. I deleted those lines from my menu.php files and everything works fine in current browsers.
