Warning: chdir() [function.chdir]: No such file
Thread begun 11/29/2010 9:28 am by kbettenc296716 | Last modified 12/01/2010 12:58 pm by Jason Byrnes | 3344 views | 4 replies |
kbettenc296716
Power CMS on this client's site, shows this error at the top of the text
Warning: chdir() [function.chdir]: No such file or directory (errno 2) in \\nawinfs03\home\users\web\b1995\rh.lbehar\CMS\WA_CMS\WA_CMS.php on line 7
link: articlesCMS.php
WA_CMS.php
$Include_Start_Dir = getcwd();
chdir(dirname(__FILE__));
require_once( "../WA_Globals/WA_Globals.php" );
require_once( "../WA_SecurityAssist/Helper_PHP.php" );
require_once("library.php");
chdir($Include_Start_Dir);
$absolutepath = str_replace("\\","/",realpath(basename($_SERVER["PHP_SELF"])));
$site_root = substr($absolutepath,0,strlen($absolutepath)-strlen($_SERVER["PHP_SELF"]));
$start_Dir = getcwd();
kbettenc296716
Warning:
I looked at this post as it seems the same as mine, but the solution did not work. The syntax was illegal.
This could be a permissions problem preventing the getcwd() command from returning the correct path.
from the getcwd() manual page
"On some Unix variants, getcwd() will return FALSE if any one of the parent directories does not have the readable or search mode set, even if the current directory does. See chmod() for more information on modes and permissions. "
what do you get if you add the following code to a blank php page:
<?php echo("The Current Working Directory is: ".getcwd().""); ?>
kbettenc296716
Current directory
The Current Working Directory is: \\nawinfs03\home\users\web\b1995\rh.lbehar
