Adding flash with sound
Thread begun 11/29/2010 7:27 am by rgodinez349368 | Last modified 11/29/2010 10:56 am by Jason Byrnes | 1248 views | 1 replies |
rgodinez349368
I tried adding flash content to the product descriptions, however, the flash plays fine, except there is no sound. Is there a particular place that the sounds should be loaded to, or a particular procedure to follow.
Are sounds not supported?
Thank you for your help.
loading flash into the product will add a standard flash wrapper that should allow audio. can you post a link where I can see the problem.
