Compatible with Site Sculptor CMS?
Thread begun 11/28/2010 4:32 pm by Lon Winters | Last modified 1/03/2011 7:27 am by Ray Borduin | 4402 views | 3 replies |
Lon WintersBeta Tester
Does the Search for Boss utility work with a site that has been created with Site Sculptor and with its content populated by the CMS?
Is so, are there any special configuration requirements? Thanks.
It should work with a CMS driven site. The BOSS search is a yahoo search, so as long as your site is indexed by yahoo there are no other considerations necessary.
Thanks Ray, that makes sense.
But how long should it take Yahoo to index the site? It's been up for almost 4 months and I even submitted a site map. Still, nothing. Google see it just fine. The site is at www.ddbikes.com.
I know this is a Yahoo issue, not a WA issue.I have it set up for BOSS, would rather not have to change the site search to something else. Any ideas? Is it possible that I may be blocking Yahoo in some way?
It seems that it is indexed on yahoo... so maybe the settings are wrong?
I did a yahoo search for rewards on the ddbikes.com site and found about 10 results and your site still has the no results message.
What did you use as your interface settings?
