error message
Thread begun 11/26/2010 12:53 pm by i.edwards384429 | Last modified 11/29/2010 8:07 am by Jason Byrnes | 2489 views | 4 replies |
i.edwards384429
error message
Hi
used the dataassist module to create the search sequence in the file boats_search.php using the search, results and details pages
I then created a sub directory ie htdocs\admin\ and re ran the da module to create an admin backend which included the delete, insert and update pages because the search criteria are different for the admin
The search, results and details pages work perfectly but when I go into the admin section and run the boats_search file I get the error below.
//save the query in a session variable if (1 == 1) { $_SESSION["WADbSearch1_admin_Results"]=$WADbSearch1->whereClause; } } else { $WADbSearch1 = new FilterDef; $WADbSearch1->initializeQueryBuilder("MYSQL","1"); //get the filter definition from a session variable if (1 == 1) { if (isset($_SESSION["WADbSearch1_admin_Results"]) && $_SESSION["WADbSearch1_admin_Results"] != "") { $WADbSearch1->whereClause = $_SESSION["WADbSearch1_admin_Results"]; } else { $WADbSearch1->whereClause = $WADbSearch1_DefaultWhere; } } else { $WADbSearch1->whereClause = $WADbSearch1_DefaultWhere; } } $WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause); $WADbSearch1whereClause = ''; ?>
I've run a file compare and the two files seem only to have the differences I would expect.
Can you please take a look and let me know where I've gone wrong?
thanks
Ian
i.edwards384429
update
Hi
I've solved that issue by starting from scratch ( all good experience)
when I now do a search an image field with the code
<td class="WADAResultsTableCell"><a href="admin_Detail.php?id=<?php echo(rawurlencode($row_WADAboats['id'])); ?>" ><?php echo($row_WADAboats['dt_boatImageThumbnail']); ?></a></td>
shows us as the file name ie image.jpeg.
I need the image to be displayed but when I use the code:
<img src="../boat_images/<?php echo $row_WADAboats["dt_boatImageThumbnail"]; ?>"
to replace
I get the yellow ? in DW and no image shows.
Where is my code wrong?
thanks
Ian
it looks like the imagetag is not being closed:
<img src="../boat_images/<?php echo $row_WADAboats["dt_boatImageThumbnail"]; ?>" />
i.edwards384429
update
Thanks Jason, looked at that for hours;-(
Trust you had a good holiday weekend???
cheers
Ian
you're welcome.
Yes, it was a fantastic holiday, thanks for asking.
