MySQL Limit function not working
Thread begun 11/26/2010 4:08 am by acaciasd344844 | Last modified 12/06/2010 7:40 am by Jason Byrnes | 6973 views | 3 replies |
acaciasd344844
Hi I wonder if you can help me. I am using the my sql count function in a recordset, but it displays the first row as a total count of the found set and then the following rows appear correctly with the found count. I have tried everything to sort this out in the sql statement and all that I could come up with was the MySQL limit function as in LIMIT 1, 100
This works when I test it within phpmyadmin, but it returns an error when added to the recordset statement. I think I know whats going on! is it because I have a Repeat Region on the page, and this sets the limit of the number of rows displayed.
My thinking was that I could use LIMIT 1, 100 as I did in phpmyadmin to hide the first row and display the rest. Can you help me out as I am unsure how to get round this.
Thanks in advance
john
instead of using the limit function in the SQL, use the php mysql_data_seek function to move to the second record:
mysql_data_seek ($recordsetName, 1);
where recordsetName is the name of the recordset.
acaciasd344844
Thanks jason I managed a work around by editing the code "$query_limit_Recordsetlivecustomers = sprintf("%s LIMIT %d, %d", $query_Recordsetlivecustomers, $startRow_Recordsetlivecustomers, $maxRows_Recordsetlivecustomers);to " "%s LIMIT 2, 100" and it worked fine thanks. I will use the mysql data seek in future though.
Thanks again
ok, glad to hear you got it working.
