PowerStore 4 Minimum Qty
Thread begun 11/24/2010 3:37 pm by rob294118 | Last modified 11/24/2010 5:46 pm by Dani Chankhour | 2565 views | 3 replies |
rob294118
Does PowerStore 4 have the ability to set minimum quantities for products?
My customers really want this option.
Dani Chankhour
PowerStore does not have this feature, but if you could explain a little bit more on how you want to implement this i might be able to help you. For example what you want to happen if the minimum quantity is not reached...
also, we might need to use eCart or other extensions to accomplish this.
rob294118
I would like to have the ability to set a minimum qty for each product sort of like the Digital Download (number of downloads). If the minimum is not met, it can just have a message that the minimum has not been met.
Dani Chankhour
It seems that you would need to implement this on the product detail page.
Basically when the add to cart button is clicked you will need to check if the quantity filed is less than the minimum quantity column from the record set, if that is the case, then you know that the minimum quantity is not met. and you can set a flag and you can use that flag to show your message.
