No results when using checkboxes
Thread begun 11/24/2010 1:06 pm by tmcbinc99963 | Last modified 11/30/2010 3:39 pm by Dani Chankhour | 2026 views | 3 replies |
tmcbinc99963
Am trying to adjust data assist to use multiple checkboxes which, as multiple selections are made, return database results, preferably on the same page. Similar to the hotel sites that update room results as checkboxes are selected.
Dani Chankhour
Do you already have the Dataassist Search Wizard applied to the page or do you need assistance in setting up DataAssist Search?
tmcbinc99963
Yes, I've already implemented the Data Wizard. If I just use the Data Wizard form fields and buttons it works fine. When I try to add check boxes, or change the form elements to check boxes, it doesn't give a search result.
Dani Chankhour
If you add a check box or modify an input field to a check box field, then you will need to update the DataAssist Search Wizard as well. The DataAssist Search wizard is able to deals with check boxes however, it needs to be configured to work with check boxes. If you reenter the dataassist search wizard server behavior, you will change the Column Type to Number/Boolean and change the type to 'Check'.
Let me know if you still have any other questions.
