Insert/Edit Image not working
Thread begun 11/24/2010 10:12 am by mrs | Last modified 11/25/2010 3:06 pm by neilo | 3374 views | 5 replies |
mrs
For some reason, I have lost the ability to upload images through the editor. The upload button has disappeared and I don't know why.
I have an error:
Notice: Use of undefined constant php - assumed 'php' in \\NAS37ENT\domains\e\ewguk.com\user\htdocs\_admin\news\tbl_news_Update.php on line 128
Line 128 is:
<?php?>
And it sits in this block of code:
$Paramfld_id_WADAtbl_news = "-1";
if (isset($_GET['fld_id'])) {
$Paramfld_id_WADAtbl_news = (get_magic_quotes_gpc()) ? $_GET['fld_id'] : addslashes($_GET['fld_id']);
mysql_select_db($database_con_evo, $con_evo);
$query_WADAtbl_news = sprintf("SELECT fld_id, fld_division, fld_image, fld_headline, fld_intro, fld_content, fld_show FROM tbl_news WHERE fld_id = %s", GetSQLValueString($Paramfld_id_WADAtbl_news, "int"));
$WADAtbl_news = mysql_query($query_WADAtbl_news, $con_evo) or die(mysql_error());
$row_WADAtbl_news = mysql_fetch_assoc($WADAtbl_news);
$totalRows_WADAtbl_news = mysql_num_rows($WADAtbl_news);?>
$maxRows_WADADynListtbl_division = 1000;
$pageNum_WADADynListtbl_division = 0;
if (isset($_GET['pageNum_WADADynListtbl_division'])) {
$pageNum_WADADynListtbl_division = $_GET['pageNum_WADADynListtbl_division'];
$startRow_WADADynListtbl_division = $pageNum_WADADynListtbl_division * $maxRows_WADADynListtbl_division;
$query_WADADynListtbl_division = "SELECT fld_id, fld_division FROM tbl_division ORDER BY fld_division";
$query_limit_WADADynListtbl_division = sprintf("%s LIMIT %d, %d", $query_WADADynListtbl_division, $startRow_WADADynListtbl_division, $maxRows_WADADynListtbl_division);
$WADADynListtbl_division = mysql_query($query_limit_WADADynListtbl_division, $con_evo) or die(mysql_error());
$row_WADADynListtbl_division = mysql_fetch_assoc($WADADynListtbl_division);
if (isset($_GET['totalRows_WADADynListtbl_division'])) {
$totalRows_WADADynListtbl_division = $_GET['totalRows_WADADynListtbl_division'];
} else {
$all_WADADynListtbl_division = mysql_query($query_WADADynListtbl_division);
$totalRows_WADADynListtbl_division = mysql_num_rows($all_WADADynListtbl_division);
$totalPages_WADADynListtbl_division = ceil($totalRows_WADADynListtbl_division/$maxRows_WADADynListtbl_division)-1;?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../../_dataimages/",
'FileName' => "[FileName]",
'DefaultFileName' => "".((isset($_POST["fld_image"]))?$_POST["fld_image"]:"") ."",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
<?php?> <<<<<---------------------------------------------////////////
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "fld_image2", "0", "", "false", $WA_UploadResult1_Params);
// WA Application Builder Update
if (isset($_POST["Update"])) // Trigger
$WA_connection = $con_evo;
$WA_table = "tbl_news";
$WA_redirectURL = "tbl_news_Detail.php?fld_id=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_keepQueryString = false;
$WA_indexField = "fld_id";
$WA_fieldNamesStr = "fld_division|fld_image|fld_headline|fld_intro|fld_content|fld_show";
$WA_fieldValuesStr = "".((isset($_POST["fld_division"]))?$_POST["fld_division"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".((isset($_POST["fld_headline"]))?$_POST["fld_headline"]:"") ."" . "|" . "".((isset($_POST["fld_intro"]))?$_POST["fld_intro"]:"") ."" . "|" . "".((isset($_POST["fld_content"]))?$_POST["fld_content"]:"") ."" . "|" . "".((isset($_POST["fld_show"]))?$_POST["fld_show"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_comparisonStr = "=|=|=|=|=|=";
$WA_where_fieldValuesStr = "".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_con_evo;
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
What's going on here then?
Dani Chankhour
To fix the error you are getting you need to remove that line of code from your page:
<?php?>
Let me know if you still can't upload after fixing the error.
mrs
OK so I removed that line of code, and the error code at the top of the page has now disappeared, however, that hasn't rectified my problem of the upload not being available. This is on the update page. See image attached.
There is a problem on the insert page too. I have html editor applied there and the upload tab works to a degree, but the link tab has the browse button which when it is clicked it opens a new window but the page cannot be found!
I've checked the files created by html editor, and they all seem to be present, so I have no idea about how to rectify this.
mrs
Just to confirm, the problem is both local and remote
mrs
I just came to check if any response had been made and found the image I had tried to upload didn't, so I have uploaded it again... cor, I'm even having trouble with the upload interface here!
I assume it is because the image was about 380 pixels deep instead of 280. Can you up the size of the image dimensions for uploading because I have had to reduce image size so much that you are unable to see what is in them!
Anyway, my problem of the image upload not working in the html editor still exists! Could you please advise?
Thanks.
neilo
Hiya, Did you enable Advanced File Management via the 'Customise Global Settings' button in the editor interface?
