Add to cart from recordset
Thread began 6/17/2009 10:57 pm by danjen | Last modified 6/18/2009 2:01 pm by danjen | 28216 views | 3 replies |
danjenBeta Tester
I have 3 add to cart buttons on one page. 2 of them were created using add to cart from recordset.
These 2 only allow me to add one item to the cart. If I click add to cart once it adds it to the cart. If I go back to the page and click another item it will not add it to the cart. The redirect takes me to the cart , but only the first item is there.
Here is the code:
// WA eCart Get Info From RS
if (isset($_POST["WA_Store_Cart_2_ATC"]) && isset($totalRows_rsRelated) && $totalRows_rsRelated > 0) {
$Redirect_redirStr="cart.php";
do {
$WA_Store_Cart_itemID = "".((isset($_POST["addtocart[]"]))?$_POST["addtocart[]"]:"") ."";
$WA_Store_Cart_itemName = "".$row_rsRelated['RelatedItem'] ."";
$WA_Store_Cart_itemDescription = "".$row_rsRelated['short_description'] ."";
$WA_Store_Cart_itemWeight = floatval("0");
$WA_Store_Cart_itemQuantity = floatval("".((isset($_POST["WA_Store_Cart_2_Quantity_Add"]))?$_POST["WA_Store_Cart_2_Quantity_Add"]:"") ."");
$WA_Store_Cart_itemPrice = floatval("".$row_rsRelated['price'] ."");
$WA_Store_Cart_itemThumb = "".$row_WADAProduct_Base['pn'] ."";
$WA_Store_Cart_itemSKU = "".$row_WADAProduct_Base['pn'] ."";
$WA_Store_Cart->AddToCart(1, "", $WA_Store_Cart_itemID, $WA_Store_Cart_itemName, $WA_Store_Cart_itemDescription, $WA_Store_Cart_itemWeight, $WA_Store_Cart_itemQuantity, $WA_Store_Cart_itemPrice, $WA_Store_Cart_itemThumb, $WA_Store_Cart_itemSKU);
} while ($row_rsRelated = mysql_fetch_assoc($rsRelated));
if ($Redirect_redirStr != "") {
$WA_Store_Cart->redirStr = $Redirect_redirStr;
mysql_data_seek($rsRelated, 0);
$row_rsRelated = mysql_fetch_assoc($rsRelated);
if (isset($_POST["WA_Store_Cart_3_ATC"]) && isset($totalRows_RelatedModel) && $totalRows_RelatedModel > 0) {
do {
$WA_Store_Cart_itemID = "".((isset($_POST["addtocartmodel[]"]))?$_POST["addtocartmodel[]"]:"") ."";
$WA_Store_Cart_itemName = "".$row_RelatedModel['RelatedItem'] ."";
$WA_Store_Cart_itemDescription = "".$row_RelatedModel['medium_description'] ."";
$WA_Store_Cart_itemQuantity = floatval("".((isset($_POST["WA_Store_Cart_3_Quantity_Add"]))?$_POST["WA_Store_Cart_3_Quantity_Add"]:"") ."");
$WA_Store_Cart_itemPrice = floatval("".$row_RelatedModel['price'] ."");
$WA_Store_Cart_itemThumb = "".$row_RelatedModel['thumbnail'] ."";
$WA_Store_Cart_itemSKU = "".$row_rsRelatedModel['pn'] ."";
} while ($row_RelatedModel = mysql_fetch_assoc($RelatedModel));
mysql_data_seek($RelatedModel, 0);
$row_RelatedModel = mysql_fetch_assoc($RelatedModel);
Can you tell me what I did wrong?
You used the wrong argument to the method:
AddToCart()
the first argument you have set to: 1
That value determines what to do if the item is in the cart:
0 = increment quantity
1 = ignore add to cart
2 = add as a new item
3 = no longer used (formerly used as redirect, but now redirect is an option for all)
4 = replace
danjenBeta Tester
Thanks a lot Ray. I appreciate your help. That fixed part of the issue. It now adds it to the cart. The problem now is that it seems it is treating it as one recordset. The code shows 2 different recordsets, but if I click either add to cart button it adds to value of the other items in the cart.
I changed the code to 0 so it adds to the value if it is in the cart.
Thanks for your help
danjenBeta Tester
I figured out the last part of the question. I had the same name used in both tables. So I have that working now.
Next issue is: I have the add to cart button in a repeating table. It lists all of the accessories in a table. If I click the add to cart button it adds the model of the fist item and the quantity of all of the items. So if the first accessory is abc and there are 4 accessories listed. If I click on the last add to cart button(item xyz) it adds abc to the cart with quantity of 4
Here is the code for the add to cart
<table>
<?php do { ?>
<tr>
<td><table width="100%" border="0">
<tr>
<td valign="bottom" width="110px"><form name="related"><input type="checkbox" name="addtocart[]" id="addtocart" value="<?php echo $row_rsRelated['AccessoryItem']; ?>" align="top"/><a href="ProductsDetail.php?SKU=<?php echo $row_rsRelated['AccessoryItem']; ?>"><?php echo $row_rsRelated['AccessoryItem']; ?></a><input name="posted" type="hidden" value="1" /></form></td>
<td valign="bottom"><?php echo $row_rsRelated['short_description']; ?></td>
<td valign="bottom" width="120" align="right">$<?php echo $row_rsRelated['price']; ?></td>
<td><form name="WA_Store_Cart_2_ATC_<?php echo $row_rsRelated['AccessoryItem']; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="WA_Store_Cart_2_ID_Add" value="<?php echo $row_rsRelated['RelatedItem']; ?>" >
<input type="text" name="WA_Store_Cart_2_Quantity_Add" value="1" size="1" >
<input type="submit" value="Add to Cart" name="WA_Store_Cart_2_ATC">
</form></td>
</tr>
</table>
</td>
</tr>
<?php } while ($row_rsRelated = mysql_fetch_assoc($rsRelated)); ?>
</table>
<?php } // Show if recordset not empty ?>
<?php if ($totalRows_RelatedModel > 0) { // Show if recordset not empty ?>
<h2 style="background-color: #D3E1FB;width:680px;height:20px;padding-top:10px;"> Recommended models:</h2>
<?php do { ?>
<hr/>
<table>
<tr>
<td>
<form name="WA_Store_Cart_3_ATC_<?php echo $row_RelatedModel['ModelItem']; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>"><table width="100%" border="0">
<tr>
<td align="left" valign="bottom"><img src="<?php echo $row_RelatedModel['thumbnail']; ?>" height="50" width="50" /></td>
<td width="100" valign="bottom" ><input type="checkbox" name="addtocartmodel[]" id="addtocartmodel" value="<?php echo $row_RelatedModel['ModelItem']; ?>" align="top"/><a href="ProductsDetail.php?SKU=<?php echo $row_RelatedModel['ModelItem']; ?>"><?php echo $row_RelatedModel['ModelItem']; ?></a></td>
<td valign="bottom"><?php echo $row_RelatedModel['brand_name']; ?><br /><?php echo $row_RelatedModel['medium_description']; ?></td>
<td valign="bottom" align="right" width="100">$<?php echo $row_RelatedModel['price']; ?></td>
<td>
<input type="hidden" name="WA_Store_Cart_3_ID_Add" value="<?php echo $row_RelatedModel['ModelItem']; ?>" >
<input type="text" name="WA_Store_Cart_3_Quantity_Add" value="1" size="1" >
<input type="submit" value="Add to Cart" name="WA_Store_Cart_3_ATC">
</form></td>
</tr>
</table>
</td>
</tr>
</table>
