XLABEL type
Hello,
during the implementation of the chart, I can see the names of resources for group 1 and for the following groups he can not play with names. Only numeric values are accepted. Will you do something to debug this problem?
It has been nearly eight hours that I turn in circles on this issue and your help will be greatly appreciated.
This works for the first graph, but not for the following:
SELECT kine AS XLABEL, ratio_etp AS YVALUE, kine AS DATAGROUP
FROM data_graph
WHERE kine_group = 1
ORDER BY ratio_etp DESC
How is it that my X-LABEL can not be text so that it works with my first graph?
For groups following example, that my graphic is being built, I am forced to use my ID resource.
SELECT id_kine AS XLABEL, ratio_etp AS YVALUE, id_kine AS DATAGROUP
FROM data_graph
WHERE kine_group = 2
I'd like to be able to display visual comfort on behalf of my resources rather than a number associated to any of my graphics. Can you help me?
View image as an attachment
Thank you
